Question about Acer AspireT135 (AST135US3302) PC Desktop
Why does my monitor not work right?
My gateway computer's monitor flashes on and off when the
computer is turned on for three minutes. We have used forced air but still have this problem. Veryfrustrating, Barbara
  • bogee Jul 06, 2008
    Problem the same all connections have been checked
    Sergeant:
  • 234 Answers
Check your power cord! and check whether loose connection is their!
Posted on Jul 01, 2008
I set the resolution far too high by mistake on my Gateway FPD1960 TFT LCD monitor. Not the screen shows "Frequency out of range". The side controls on the monitor do not respond. Please help,if you can.
Hi
Firstly try turning everything off and disconnecting from the mains. Leave for a few minutes and then turn them back on again. This should set the monitor back to default setting, and also the computer.
If this doesn't work, try connecting the computer to a different monitor and using the "display properties" to set the display card to a resolution that you know the Gateway monitor will accept eg probably 1024 x 768. Then reconnect the computer to the Gateway monitor. This should work as the computer usually sets the monitor resolution.
If this doesn't work the only other option I can think of is to use the buttons on the monitor to get into the onscreen menu, which should be resolution independent and using the menu to change the resolution.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 07, 2015 | Gateway Computers & Internet
My gateway monitor shows a picture for about 1 second then turns to blacked out screen with power light still on. I can shut the power off on the monitor then turn it back on only to have it do the same...
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Hope that helps.
Nov 01, 2009 | Gateway HD2201 22" LCD Monitor
Gateway Monitor FPD2485W
posibly a burnt out CCFL light , more likely an overloaded or burnt out CCFL power supply
JOAT
Oct 16, 2009 | Computers & Internet
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
When turn on the gateway screen apear, but the monitor turn off or black and not apear nothing my computer is gateway profile 4 all in one
Mar 13, 2009 | Gateway Profile 4 All In One (MPN...
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Fx70 pavilion 15
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Acer AspireT135 (AST135US3302) PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
