Question about Kenmore 46462 Front Load Washer
Kenmore HE2 Front Load Washer will not drain....please help
After final rinse the washer will not drain
  • ang c Sep 29, 2008
    My front load washer wont drain. Its only a year old and I only put in a small load. I also tried to take the wet clothes out and run it, but the water still wont drain. Any ideas on what to do?
  • Anonymous Mar 31, 2014
    took out rubber drain and there is a ball in it? should it be there?
Clean the drain trap....while the drain trap is out check the drain pump somtimes small debris, baby socks, and other smaller materials. like,. rubber bands, and such, get stuck in the propellers....just cleaned my out, and found a girls hair band in there, removed it, put back together, filled it up and drained perfectly!!!!!
Posted on Dec 11, 2008
  • 57 Answers
Hi I would advise you to check the pressure switch
Posted on Jul 18, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
Washer will not spin out on the final cycle and then shut off
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 25, 2011 | Kenmore HE2 Plus Front Load Washer
The Kenmore HE2 Washer Model 11046462501 Selector dial lights blink continuous with status lights Add a Garment, Rinse, Clothes Clean lights lit. What does this error mean ?
This IS the code for drain problem, pull front panel and remove round filter by turning to the left, probably full of change, feel the pump to the right of the filter if it is HOT, replace it...
Aug 09, 2010 | Kenmore HE2 Plus Front Load Washer
My washer does not seem to be going through the rinse cycle.It doesnt drain all wash water out. When it FINALLY stops the letters Sd are lit............WHY
overdose of detergent during wash cycle try running the unit in a rinse spin here is also a tehnical sheet that u can get from this site as a pdf sd stands or suds lock http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Apr 02, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 46462 Front Load Washer Logo
203 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
