Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Downloading photos I have 300 photos on the card and need to print the last one. According to my dad I have to download all of them before I can access the one I need. It takes about 90 seconds per photo. Is there anyway I can speed this up? Sorry this isn;t very technical but none of us has ever had a digital camera before. I persuaded Dad to exchange his old camera for this one and am fast regretting it!!!
Depending on what you are using to download your pics with, you should be able to select within the program, which pics you want to download.
Also, make sure the program doesn't auto-delete the pics after you download them, I found that out the hard way.
Posted on Jul 16, 2008
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
300 dpi print
go to the cannon website and check their support/downloads
Dec 23, 2013 | Canon LASER SHOT LBP-2900 Printer
Last software download
are you trying to download your photos onto your computer if so you can take the sd card out and put it in your computer slot for sd and download them from there. or you can go onto computer and download the software for that camera.
Jan 24, 2013 | Olympus MJU 300 Digital Camera
My brand new Lexmark S-300 all in one scanner, copier, printer will not scan when I place a document on the glass and press the buttons according to instructions. It prints and copies fine.
hi, just download and install the Lexmark S-300 scanner driver. you can search it on Google or re-install your Lexmark S-300 all in one scanner.
Jan 29, 2011 | Computers & Internet
I have a brand new camara with about 300 photos I am trying to download pics to computer and the camara will not read the card - i have turned on & off removed card and re-insurted and made sure...
The Canon EOS Rebel G is an all-plastic 35mm SLR film camera there is no way this camera model can download pictures to a computer, it's a film camera. If you have miss printed the model correct the error and resubmit the question.
Nov 27, 2010 | Canon EOS Rebel G 35mm SLR Camera
How do i only download NEW photos on to my pc? it keeps downloading 300 photos.....
Connect your data cable with computer to camera.If the computer needs the camera driver install it .Then you can find the camera is detected ,Now you can download your photos to your computer.Or you can take the memory card out from camera and connect it with memory card reader to computer then you can download your photos
Sep 05, 2010 | Canon PowerShot S500 IXUS 500 Digital...
I have installed my epson sp 1410 onto my mac 10.6.2 but its not printing. i have downloaded sofware so mac will read epson, red ink light is on and steady, green on light is also steady why won't it...
According to the manual this would indicate one of the following.
Ink carts not installed
Wrong carts installed
Carts not installed correctly (try taking out and replacing making sure rhe locking tabs are fully home.)
The last semms the most likely.
Jan 07, 2010 | Epson Stylus Photo 1410 Printer
What happens if you press the shutter button on your camera and you have no memory card installed will you break the camera
According to the manual your camera does have an internal memory, so shooting with no SD card installed will simply result in internal photo storage. Using the camera's MENU you can select or deselect the option to "Shoot w/o card." Selecting ON will store photos in the internal memory, while OFF will divert all photos to the card. Attempting to shoot with the option OFF and no card installed will prevent the camera from taking photos and display a message. I could not find information on the number of photos that can be stored on the internal memory.
Need the manual? You can download/print it here:
http://snpi.dell.com/sna/manuals/A1761803.pdf
Dec 25, 2009 | Cameras
Kindly send me th link for A540 software download
Do you wish the software to download the photos from your camera? If so, as a better solution I highly recommend that you instead consider a card reader to download your photos. Card reader's are very inexpensive, much faster downloading photos from the camera, do not use the camera's batteries during download, and are much less prone to file corruption of the photos during the download.
You place the camera's card in the reader, plug the reader into the USB port, and your computer sees it as a hard drive. No software is needed. You simply copy/paste or drag/drop your photos onto your hard drive. For this simplicity, most professional photographers utilize card readers exclusively. Really, you'll save yourself a lot of trouble. Here are some examples from Amazon. Also, don't be fooled by the cost. Some of the inexpensive ones work just fine. Go by the reviews. Also make sure you get a reader that is stated capable of reading your card (particularly if you have an SDHC card)::
http://www.amazon.com/s/qid=1232260593/ref=sr_st?keywords=sd+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Asd+card+reader&sort=acrelevancerank
For international purchases, here's another source for card readers (low prices, free international shipping too :-)
http://www.dealextreme.com/products.dx/category.300
Jan 23, 2009 | Canon Cameras
Canon A460; Downloading pics to computer
It's very hard to troubleshoot software problems online, and it likely is a software issue. But as a solution I highly recommend that you instead consider a card reader to download your photos to your computer. They're very inexpensive, much faster downloading photos from the camera, do not use the camera's batteries during download, and are much less prone to file corruption of the photos during the download.
You place the camera's card in the reader, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For all of these reasons, most professional photographers utilize card readers exclusively. Really, you'll save yourself a lot of heartache. Here are some examples from Amazon. Also, don't be fooled by the cost. some of the cheapest ones work just fine. Go by the reviews. Also make sure you get a reader that is stated capable of reading your card (particularly if you have an SDHC card):
For international folks, here's another source for card readers (free international shipping too :-)
Jan 19, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
