Question about ViewSonic VPW425 42 in. Plasma HDTV
Viewsonic VPW425 No inputs working
I have a Viewsonic VPW425, that stopped working after an electrical storm in the area. I assume something got hit and damaged the TV.
Currently I canno got it to display any picture other than the on screen menus and etc.
If I hook cable to the tuner, it displays that it detects and finds the channels, but when I tune to them no sound or picture.
I have tried the RCA jacks with the same results.
I have not yet tried the DVI or RGB, but assume the same issues.
Any ideas on how to repair?
  • voodoochief Jul 03, 2008
    The TV Does power on, and I do see the menus though. In fact I can tell it to scan for channels on the CABLE TV Tuner and it even finds the channels, but when i turn to them, nothing is displayed, except the built in screen saver and onscreen menu.
    Do you still think it is the fuse?
    I did take the back off and look for blow components or burned boards, etc. did not find any. nor did I find any blown fuses. I tested ALL the fuses I found with an Ohm meter just to make sure.
    may have been one i missed though, if you still think this is the issue, I will take it back apart and see.
    Genius:
  • 1,847 Answers
Seem like the power supply hav blow off inside the unit.
Posted on Jul 02, 2008
  • Legin Varghese
    Legin Varghese Jul 02, 2008
    electrical storm usually hits the fuse or the power supply inside the unite. you have to the screen back cover and check the fuse in the mother board, if that is intact the power supply need to be changed.
Can burn in images on vpw425 viewsonic be fixed
maybe
http://www.makeuseof.com/tag/why-do-images-get-burned-into-lcd-and-plasma-displays-and-how-you-can-fix-it/
Dec 28, 2014 | ViewSonic VPW425 42 in. Plasma HDTV
Viewsonic vpw425 has burn in images can they be removed
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
VPW425, The AV1, AV2, TV inputs are not working, Just the 2 HD inputs work.
Some tv's are "modular" this means that some parts are replaceable, remove the back of the set and have a look at where the inputs are located, this is just a starting point, you could try replacing the part which the sockets are connected to. ( do a google search for any numbers etc which you can find on the part in question.
May 02, 2011 | ViewSonic VPW425 42 in. Plasma HDTV
How do I remove the Hd compatibility message from top of screen?
Go in ur tv menu go to Option go down the menu check the Program Title Dsiplay pick no.That should take away the HD signal sign.But some tv must have that HD sign,to tell u it in HD programings.
Apr 03, 2010 | ViewSonic VPW425 42 in. Plasma HDTV
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Hp 2210 all-in one everything works except the fax. I have to connect the cable to the phone jack and not go through the computer. the happened after we had a electrical storm. I hope there is something I...
Assuming that your fax worked before the storm and stopped working afterwards, I don't think there's much you can do if the storm fried the circuit board. You could try uninstalling and reinstalling the printer to see if the storm did something to the configuration settings, but I suspect a power surge damaged the fax modem in the machine.
If it's still under warranty, you could call the place where you bought the printer and see what it would take to fix it. I suspect having it repaired out of warranty would be more expensive than it's worth.
Oct 03, 2008 | Office Equipment & Supplies
Water and a plasma tv
I am sure that there is damage to any of the boards that got wet, or had residue from being wet. The voltages in these sets are fairly high, and thus there is damage. Sometimes a damaged board can cause damage on other boards that are connected to it.
Before writing off the set, give it to the factory service rep just in case it may only be a failed board that is not terribly expensive.
If you had a flood and you have house insurance, find out if you are covered. In this case, let the insurance company deal with the set.
Jerry G.
May 15, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Have parts for Viewsonic VPW-425 42"
If these are used parts or from a scrapped set, buying used parts would be a very risky investment.
Jerry G.
Apr 13, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Broken plasma tv screen.....nec model
SoCalRugger,
The plasma usually has 2 sheets of glass, the outer one sounds ok which is not good news as these can be replaced.
The inner panel is the actual plasma layer and if it is craked or broken it usually requires a swapout for a new panel.
Jan 25, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Jan 22, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
ViewSonic VPW425 42 in. Plasma HDTV Logo
311 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
