Kitchen Ranges
Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
CLOCK/TIMER
By HARRYM38 on Jul 01, 2008
DISPLAY DOES NOT WORK, RANGE IGNITERS WORK AND GAS BURNERS LIGHT
Same Problem
Nov 16, 2008
-   Display doesn't work so the oven/broiler will not work. The stove top and lights and everything else works. The display just has one "dot" lit in the upper right hand corner.-   cfkirchner
Sep 13, 2008
-   the LCD display fades in and out. Sometimes if pressed it will display for a short time than go out.-   R_Jantzi
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
Answer
which brand Dual fuel slide in range is the best?
Answer
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot,... (More)
Answer
Lower oven will not heat, upper oven and stove burners work fine. I took of the base panel and tried... (More)
Answer
oven temp fluctuates +/- 25 degrees from selected temperature
Answer
The rear rear burners and oven will not ignite. I can light the reart burners manually.
Describe your Kitchen Ranges problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Range Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
