Question about Motorola Mobility RAZR V3
Security Code Want to get past security code to enter phone but when turn the phone off I want the security code thats in there to still work. I guess what I'm asking is can I get in and out undetected - Is that even possable?
    Brigadier General:
  • 7,752 Answers
No you need to either remember the code or have the code reset
Posted on Jul 01, 2008
Suddenly asking for security code, 12345 doesn't work
if you do not or have not ever put a security code on the phone I would suggest entering the default for Nokia which is 12345 also to get your IMEI # you can enter # 0 6 # to get simlock info enter # 9 2 7 0 2 6 8 9 # to get software version enter # 0 0 0 0 # these codes do work on the nokia 6110 but not sure if they work on other versions of Nokia phones except the security code is always 12345 if it is default and has not been changed of course you have to get past the security code first.
Nov 16, 2009 | Nokia 6110 Cellular Phone
Nokia 3585 security code lost and how to unlock network ?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-3585
SECURITY CODE from page 54 of your manual:
Your phone prompts you for a five-digit security code for certain features and commands.
Access is granted only after the correct security code has been entered successfully.
The default security code is 12345. It is recommended that you change this code at once,
write it down, and store it in a safe place away from your phone.
Important: When entering your security code, ***** is displayed on the screen to
keep others from viewing your code.
You can delete the last entered digit by pressing Clear (or by pressing and holding Clear to
delete all the digits more quickly). Enter the correct code or press Back to exit. If you enter an
incorrect security code (Code error will appear) five times in a row, your phone won’t accept
any entries for the next five minutes.
Change your security code
1 Press Menu 4-5-2-4 (Settings > Security settings > Access codes > Change security code)
and press Select.
2 Enter existing (or default) security code and press OK.
Security and System settings
3 Enter new five-digit security code and press OK.
4 Re-enter your new five-digit security code for verification, then press OK.
Your phone displays the confirmation message Security code changed.
Important: If you change your security code and don’t remember the new code,
contact your service provider. Once you change your security code, the default code
is no longer valid.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 19, 2009 | Nokia 3585
Security code problem
In case the security code is entered incorrectly for more than 5 times, then the phone does not accept the correct code for approximately 1 hour. So try the correct code after 2 hours and then check again. Do not enter any code for 2 hours to make it work.
Please rate this solution.
Aug 25, 2009 | Nokia 3109 Cellular Phone
How can i change security code which i forgot nokia 3110 classic?
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 23, 2008 | Nokia 3110 Cellular Phone
Security code
SIM pin code:
Master Reset Code
Security code Nokia 3110 classic
SIM pin code:
Master Reset Code
Apr 17, 2008 | Nokia 3110 Cellular Phone
Resetting Security Code
SIM pin code:
Master Reset Code
Apr 13, 2008 | Nokia 3110 Cellular Phone
Unlock Nokia N95 8GB
plz give nokia n95 master cod
Apr 05, 2008 | Nokia N95 Cellular Phone
Forgot security code
i forgot my phone security code.my cell is 3310.can any one help me pls!! my imei no. 351106105391536
Mar 10, 2008 | Nokia 6600
Nokia 6265i
There's a Security Code and Lock Code.
Resetting the Lock Code:
Remove the battery and replace it after 1 hour or more. The default Lock Code should reset to "1234". If that doesn't work try the last four of your phone number.
Resetting the Security Code:
The default Security Code is 12345. If this doesn't work go to your normal interface and type in "#3001*12345*. Go to the Security option, write down the number, then press "Ok". Back out of it all and it should take you back to your normal phone interface. The number your found should be your security code.
Feb 16, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
