Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner on HP6110
My HP6110 works in all modes except scanner. When I try to scan, I get the message computer not connected.Yet it is connected (prints just fine) and in the control panel I tested the scanner and the message says "your device successfully completed the diagnostic test." Why can't I scan?
I also have this problem. Try going to
-Start
-Programs
-Accessories
-Scanner and Camera Wizard.
I can get my scanner to work through the wizard when it won't work by just pressing the scan button on the printer.
Posted on Jul 01, 2008
Good day, why craftsman diagnostic scanner show 'communication error' whenever it's scanner Nissan vehicles
PDF]Communications Could Not Be Established with Your ...
www.wisconsinvip.org/WivipPublic/PDF/.../noncom052108.pdf
May 21, 2008 - computer alerts motorists of problems with the vehicle's emission control ... tampered with and the connection to the on-board diagnostic (OBD) ... itspower from the same circuit as the cigarette lighter. ... scan tool, connected to the data link connector (DLC) under the dash, not ... General Program Questions.Missing: craftsman ‎whenever
[PDF]OBDII ABS and Airbag Scan Tool - Actron
https://actron.com/craftsman/scan-tool/.../568593-Craftsman-39853-MN...
OBDII ABS and Airbag. Scan Tool. Model 39853 .... OBD II Diagnostic Trouble Codes (DTCs) . .... Program Mode . .... Error Messages . ... Vehicle Communication Fault ...... No warranty (expressed or implied) can be made for its accuracy or completeness... Go to www.actron.com/craftsman to download the Scanning Suite.
Scan Tool Help
www.scantoolhelp.com/
A scan tool is a must for automotive diagnostic work today. ... 1996 and newervehicles (one exception is Nissan), and (2) counting the series of flashes can be confusing. ... II monitors (ready means the monitor has completed its self-check process). ... with bidirectional (two-way) communication capability and the proper ...Missing: craftsman ‎whenever
Automotive Diagnostic Scanners -- OBD-I and OBD-II
www.mikeogara.net/improve_your_car/auto_scanners/
Jan 31, 2016 | Nissan Cars & Trucks
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
I am trying to scan and i get the message "communication error - make sure computer is connected - i am using wireless and the printer works what do i have to do to make the scanner work?
To work around this problem, you must create a Windows Firewall exception for TCP port 21. To do this, follow these steps:
  1. Click Start, click Run, type firewall.cpl, and then click OK.
  2. In the Windows Firewall dialog box, click the Exceptions tab, and then click Add Port.
  3. In the Add a Port dialog box, type Scanner and Camera Wizard in the Name: text box.
  4. In the Port number: text box, type 21.
  5. Click TCP, and then click OK.
Restart the computer and now you should be able to scan.
Cheers.!!!
May 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
Do the following:
Uninstall the scanner from your computer
Restart
Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
Restart again
And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
I can't get my hp 6110 to scan to my computer
GO to add scanner utility and try to add the scanner if it ask for the driver insert the disk.
May 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have two computers both use a seperate hp6110 and both will not turn on. Happened on the same day no power either unit. Everything around them works except the HP's
disconnect the power cable for your printers as well as the computers and reconnect them.
if the computers are on then there should be no problem with the power supply. try and connect your printer in hte same power supply.
if still not working then try connecting your computer to the power supply where you have connected the printer. if the computer is not working in the power supply then the problem is with hte power supply.
Feb 18, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
Keep getting scanning error message
How do you have the HP6110 connected to your system? This problem can sometimes be caused by using to long a cable between the computer and the multifunction printer. I would use a short cable (6 foot or less) to make sure that it's not a communications problem. This ususally manifests itself with an error message while scanning although the printing function work ok.
Apr 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
