Question about Acer Aspire 3680 Laptop
Acer 3680 keyboard
How do I remove the keyboard?
    Genius:
  • 2,028 Answers
Keyboard removal work one of two ways on about every laptop out there. 1- The screws holding it are on the bottom of the machine, sometimes marked with a K. 2- The screws are under the power button strip at the top of the keyboard, the strip snaps into place, so lift up on one side and work it up and off. Here's a couple of links for laptop breakdown diagrams. You should be able to find your machine there or at least a similar one to give you an idea.
http://repair4laptop.org/notebook.html
http://www.eserviceinfo.com/service_manual/datasheets_d_600.html
Posted on Jul 01, 2008
My acer 3680 laptop's keyboard is not working
The keyboard may be faulty and if so you need to replace it.
To determine if the keyboard is faulty or the keyboard controller chip is faulty, connect an USB keyboard to your laptop and if the keyboard functions correctly then the laptop's keyboard is faulty.
Replacement keyboard is available from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jun 05, 2011 | Intel Computers & Internet
Hi, i'd like to have some instructions on how to replace the keyboard on my acer 3680 ,thanks
Hello.
Glad to Help You.
There should be a panel above the keyboard that is usually held in place by a series of tabs. You will need to pry it up. Starting from one corner, gently lift it until you can remove the entire panel. If it seems overly difficult, look around the LCD hinges for screws, some laptops have them. You should find that the keyboard is held in place by 2 - 3 screws at the top, remove these screws, lift the keyboard, whilst being careful with the ribbon connector.
df9c1ee.jpg**********************************************************************************
Attention! Be very gentle with the keyboard connector on the motherboard.
f you break the keyboard connector, you’ll have to replace the entire motherboard or use the laptop only with an external keyboard.
Good Luck.
Nov 03, 2009 | Acer Aspire 3680 Laptop
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
I need to change the keyboad on my acer 3680-2633 lap top and c
Laptops have screws that secure the keyboard, they are located on the bottom of the laptop directly under the keyboard. There maybe up to 4 screws holding the keyboard in place, remove these screws. The keyboard should be able to be lifted off to reveal connecting cables. There will be one or two ribbon cables that connect the keyboard to the motherboard, carefully detach these cables before you completely remove the keyboard.
Apr 02, 2009 | Acer Computers & Internet
''NEED TO REMOVE THE KEYBOARD ON A ACER ASPIRE 3680 2233''
Remove the screws on the both hinge,be carefull when you revove the keyboard backwards, its all plastic and verry verry easy to breake.
Nic
Mar 12, 2009 | Acer Aspire 3680 Laptop
Keyboard Acer 3680-2682
plug a USB or PS2 keyboard in externally or see our service database for a repair station in your area
Sep 15, 2008 | Acer Aspire 3680 Laptop
Acer 3680 keyboard
you will hve to see if they clip on, otherwise it's a new keyboard, but i would'nt try and fit that myself.
Sep 06, 2008 | Acer Aspire 3680 Laptop
Changer
The charger is part of the motherboard, you will need to strip the whole machine...
Jan 02, 2008 | Acer Aspire 3680 Laptop
Parmiters for acer aspire 3680 laptop
Hi, heres a few for sale cheap, http://www.ebuyer.com/cat/CD---DVD-Drives/subcat/Slimline-Drives
all you need to do is remove the keyboard on the laptop, and remove screws, once you have it open you should see a screw holding in the old dvd drive, just unscrew it and take it out and refit the new one and seal it back up and thats you..
Have a nice christmas
John
Dec 03, 2007 | Acer Aspire 3680 Laptop
ACER 3680 KEYBOARD
there are many many different keyboard designs, it is hard to make a suggestion...usually if it looks like nothing is broken on the key or keyboard you push down firmly and it snaps back into place.
Oct 03, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
