Question about Maytag MZD2766GES Side by Side Refrigerator
REFEGERATOR NOT GETTING COLD
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way
  • 481 Answers
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Aug 12, 2008
My rv refegerator freeezes as if it was the freezer as low as twenty degrees any help would be appricatedThanks Brian
sounds like you need a new thermostat. refrigerator section should be between 34-40 degrees. is the temperature in the freezer ok? what setting do u have the thermostat set at?
Feb 04, 2011 | Dometic RM2652 Refrigerator
Freezer is freezing up, heaters and defrosting , refegerator not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
System has a leak and is low on charge...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
I just bought a pretty old, used GE fridge. (It's a freezer on top model.) The fridge is cold but the freezer isn't cold enough. It just barely makes ice part of the time. Ice cream defrosts and bread...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 24, 2010 | GE Refrigerators
Kenmore 21 refrigerator not getting cold - freezer still pretty cold (top) - perhaps not all the way
you have a defrost prblem or a leak in the sealed system.if you see frost built up on back freezer wall then it is a defrost problem also check evaporator fan motor to see if it is running.if machine is in defrost you wont hear it.so when compressor is running see if fan is running.
Mar 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com refrigerator not getting cold - freezer side is working
  • possible causes:
Jul 01, 2008 | Maytag MZD2766GES Side by Side...
Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Dec 19, 2007 | Maytag MSD2456G Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
271 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
