Question about Pioneer HTS-GS1 Theater System
Sound Issues I just booted up my system, and was only getting sound on the right side. When I listened closely, there was a soft static coming from the center and left speakers. I could also hear a bit of sound from the program I was watching. When I ran MCACC, all the speakers worked perfectly. I checked multiple channels and music from my pc, but nothing worked.
  • Anonymous Nov 05, 2008
    only one of my speakers work except my left surround sound one .. and i made sure all the connections are correctly connected
    Scholar:
  • 66 Answers
Ah that's the problem, Pioneer has been famous for audio problems. Your model is a newer one that uses a system scanner to detect audio problems. Check your wires and see if they are connected correctly. To be honest, as an expert on Home Theater systems, Pioneer is not the best way to go, Boston Acoustics is a really good system, pricey, but good.
Posted on Jul 01, 2008
Sound comes in strong and weak at different times
It could be that or a loose wire to one side of the speakers in the set. If it does it often enough locate where the actual sound for each side of the set is located---when it does it get close and listen---if one side is low or distorted you know it is either a connection or speaker on that side OR since most sets have a left and right channel for sound--the issue is in one side.(circuit problem)
Dec 05, 2012 | Vizio VF550M 55 in. LCD HDTV
My husband purchased Bose compnion 5 in Singapore last December. He tried it last night but the right side speaker had a very soft sound compared to the loud sound from left side speaker. How do we fix...
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 31, 2011 | Bose Companion 5 Multimedia Speaker System...
My speaker on my asus eee 1000he is not working corectly. I'm unable to here people speak they sound as if the volume is turned way down and can not here most music clearly. Even with headset it does not...
the sound card in n that netbook is a very weak one, alot of people complain, could be that
could also be that you have the wave volume turned down...
go to start
control panel
sound and audio devices
right under the volume slider click the advanced tab
make sure all tabs there are maxxed out
if that doesnt work
turn dolby on, suposedl;y that helps...
if that doesnt work, turn the volume up all the way, play a soft song, like saxaphone music, adn get the speaker close to your ear, if you can barely hear the music, and get about the same amount of static or white noise, you have a shorted circuit with the internal sound system...
Jan 08, 2010 | ASUS Eee PC 1000HE Netbook
Toshiba loud speakers on fritz. Right Side Works; Not the left
I assume that this is part of a computer system. If it is, I would start with all cables, then check to see if you recently got an updated driver for the card and if so roll it back to a previous one. If these are not the case, you may try to open the case on the computer and remove and reseat the card and check the audio input cable on it to be sure it is fully seated. Be careful in your case
Jun 09, 2009 | Toshiba (4CH-VOUT) Sound Card
I looking for to listen mp3 songs.but sound is not come what i can do
If it is a desktop-
1. Check if your soundboxes are connected to your computer. If yes go to no.2
2. Check if your system volume (or sound) is in mute. (Extreme right hand bottom corner, look for a mic symbol. If it is strikethrough then it is in mute)
If it is a laptop then-
1. Check if your computer is not in mute condition. (See the right hand bottom corner of your laptop)
If no other problem is there, then probably your computer does not have the sound card installed.
Apr 23, 2009 | AB Soft Computers & Internet
I HAVE STATIC BUT NO SOUND
Check the configuration on the pc if this is what you are connecting it to and make sure that there is not an option to reroute the sound out the audio jack. Also make sure that the sound level is turned up for the audio you are trying to listen to such as wave.
If this is for a radio or an ipod type of device make sure that the jack is in all the way and not just most of the way. If it is not in all the way you can hear static but not the sound.
Lastly, make sure that you have it plugged into the audio out and not the microphone input side.
hth
Feb 18, 2009 | Altec Lansing VS2121 Computer Speakers
I have the sound divice but i cant play any thing and i dont here
possible sound device failed, or drivers not the right ones, my newer note book had failed sound device (code 10 cannot start) it started doing static when listening. the failed all the way. i now use an external sound device myself that was about 15 dollars now i have sound again without large cost. this may be an option for you.
Nov 18, 2008 | Digidesign Mbox External Sound System
Emachines
Hi Che,
There are a variety of issues regarding a computer not booting up. There are hardware and software issues associated with it. You can approach the problem through the following steps:
1. Clean your unit with a soft brush, avoiding too much pressure applied to the sensitive components. See if the cards inside your computer are free of dust. Brush off dust from the cards and your mainboard.
2. You may remove the cards (video card, memory modules, sound card, LAN card, etc.) from their slots and reinsert them. Interfacing parts tend to be clogged with dirt through time. Just make sure you have removed static electrical charges in your body by placing your hands on the sides of your CPU. Hold the cards by their edges.
3. Make sure that all connections are firmly plugged.
If this doesn't work, you can try booting your computer using a bootable disc (such as those used in installing OS) and choose repair. When the c: prompt appears, type scandisk (for Windows 98) or chkdsk (for Windows XP). Once it's done, this should repair boot problem.
Sep 02, 2008 | E-Machines eMachines Desktop PC
Power light comes on but nothing else happens
hi
when you power up ,turn the laptop around and listen closely underneathfor the sound of the hard drive ...no sound =goosed HD
Jan 10, 2008 | Dell Latitude CPX Notebook
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Pioneer HTS-GS1 Theater System Logo
134 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
