Question about Whirlpool LER5636P Electric Dryer
Dryer smells after painting
What would you suggest we do to get the smell out?
  • 417 Answers
did you paint the dryer? did you use high temperature paint?
eventually it will just wear off or sand it off and get high temp paint from auto parts store
J
Posted on Jul 11, 2008
Smell rubber
i have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps
Jan 19, 2014 | Dryers
Notice a "rubber"smell this winter. The lint vent is clean after each use, outside vent is clear of any debris. can the wind blow smell back into house or is it a belt? Installed new by dealer 1/9/13.
I have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
hope this helps
Jan 19, 2014 | Whirlpool Dryers
I have an LG gas dryer, lately when the dryer has finished my clothes has a burning smell to them. I recently painted and noticed the smell at that time. Though the paint smell is gone the burnt smell has...
Mark, My name is Hal and having trouble understanding where you painted. Did you paint the inside of the drum? Or did you paint the house interior?
If you painted the inside of the drum did you use a high temperature paint? If not, that could be your problem since the dryer does get very hot inside and it could be melting your paint.
Aug 06, 2011 | LG DLG5988 Gas Dryer
Chemical like smell while clothes are drying
If you have recently painted or varnished something then just air out the house. The fumes can react w/ the heat of the dryer to create this smell. It smells different than the actual fumes, but still like some sort of solvent.
Jul 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Burnt smell when dryer running
it could be what your washing your clothes with.
Feb 28, 2009 | Whirlpool LEQ9858P Electric Dryer
Our Kenmore HE3 front loading dryer gives off a fuel smell inside
When I had the back off of the dryer I did notice one thing that looked a little unusual. The vent
pipe, which the flame of the burner travels through, ( running from the burner to the back of the
dryer ) was painted, inside and out. Some of the paint was cracked and slightly bubbled, as though
it was melting from heat, and there actually was a small pile of soot laying there. I wiped off as much
of the paint as I could with a rag, and vacuumed it out, and put the dryer back together and ran it.
After running the dryer for a while we no longer have the smell. I don't really know if that was the problem
or not, but at least the smell is gone.
Dec 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
My clothes smell burnt
If you have done any recent painting or drywall work, oftentimes the dryer will breathe these fumes and it will affect the smell of your clothes. (Just had the same problem) Maybe let the area air out and see if that corrects your problem
Nov 28, 2007 | Kenmore 74832 Gas Dryer
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
