SOURCE: Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
SOURCE: Dishwasher fills w/ water, does not wash, but does drain.
Joel, it's hard to tell whats going on here without the full model number. The number you posted should start with a 665, 363,587 or 464. Here is a couple of things to look for. It sounds like you have a seperate drain pump. Remove the bottom toe panel and hopefully there will be a tech sheet behind it. Check the harness to the motor itself. You want to verify that there is 120V going to it when the wash motor should be running. If you hear the motor humming and kicking out on the overload, then we can assume you have something stuck in the impeller or the motor is bad itself. The tech sheet will give you a diagram for the hot and nuetral. Check the float switch inside the tub, it should move freely up and down. This is a safety device to insure the dishwasher does not overfill. If this is a 665, there will be a start capacitor on the left side of the wash motor. If one of the wires came off the cap, the motor won't run. Regarding the door switches, if you have 120V going to the motor during the wash cycle, you can assume the door switches are o.k. Hope this gets you started in the right direction...Catriver.
SOURCE: Kenmore Ultra Wash Diswasher - wont move past initial cycle
Motor trying to start. blockage in pump, or bad motor!
SOURCE: I have a Kenmore dishwasher that will not pump
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
SOURCE: Kenmore (Whirlpool) 655 1589910 Dishwasher.
you need to clean/ check the chopper. sounds like you have a bad motor. about 2-300 dollars for the part
