Question about Panasonic CT-32G11 32" TV
Intermittent power on/off
Set will turn itself off, then on again, repeatedly and will eventually stay on after cycling various times. Did vacuum back of exterior, seemed to help for about a week. Also, seems to correct itself (not 100% sure), if you catch it while on and turn off then wait 5 min, seems to turn on and stay on.
My exact same TV did the same thing. Your fuse us going bad. Go buy a new one and replace it.
Posted on Jan 13, 2009
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Equipment: American Standard/Trane model THS 120A960B2 Horizontal- Intermittent electronic ignition. Fuel: LP Problem: burners ignite then turn off. This on /off cycle repeats 4-5 times and then...
Could be flame sensor. I dirty flame sensor will cause this problem. Flame sensor is rod that is in burner, should be able to remove and clean with steel wool or dollar bill. Usually has white film on sensor preventing it from reading flame. Not sure how American Standard is but sensor normally has 1 screw holding into place in burner box. If you can get at it, it is easy to clean.
Jan 24, 2011 | Goodman Heating & Cooling
No power
your on off switch button need to replace or try to spray contact cleaner then press on and off a few time and pls unplug the power cable first ok
Mar 24, 2009 | Televison & Video
No power
Did the set just turn off and stay off? Has the set been turning itself off and then back on before this issue. If you push the power button, does set set cycle on and of 3 times?
If it just went off and stayed off, the first thing I would check is the main fuse near where the power cord goes into the set. You'll have to take off the back and then unscrew and unclip the plastic cover in the back where the various inputs and out puts are. Looking down after removing the plastic cover you'll see a glass fuse that snaps onto the board. Check and replace that fuse if it's bad.
If the other symtoms I mentioned happen then it's most likely the HV splitter up in the front part of the set.
Nov 18, 2008 | Proscan PS60690 60" Rear Projection...
Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
Aug 15, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
RCA D52W20 Intermittent Power Issue
your problem is intermitent resolder the power supply the horizontal along with the area of the flyback you could be having some lose solder also resolder.if that does not work check around in the power suply some bad cap,power regulator and even the flyback again.a check should be made on the microchip.if you cannot do it your self take the set to a tech.good luck
Mar 29, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
291 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
