Question about Dell Inspiron 6400 Notebook
Sleep problem After the first boot if I send my inspiron 6400 to sleep everthing works normally. However on subsequent attempts to send the machine to sleep (without an intervening boot) sleep does not work. When I send my notebook to sleep mode the screen goes blank but the machine does not enter sleep mode. However if I touch to mouse pad, hit enter etc the screen wont switch back on. Any suggestions? Many thanks
  • patour Nov 25, 2008
    I have a new Acer Monitor; goes into sleep mode after not using for a little while, I will move the mouse, hit the keys but can't get the screen to come back on.
    Genius:
  • 2,028 Answers
I've seen this on many Dell machines, and I've found no real fix for this. It seems that this function either works or it doesn't. You can do a restore back to a point that you remember it working properly, but eventually it will start doing it again. I've decided that this is a glitch with Dell's systems. You can also do a bios update from Dell's support site, sometimes this helps with the little glitch they pick up.
Posted on Jul 01, 2008
My dell inspiron E1505 will not go into sleep mode. How do I fix this? Already checked pc settings and they are correct.
Enable power save features and sleep mode in BIOS
On boot , press F1 or F2 to get into BIOS , check standby settings .
Aug 13, 2013 | Dell Inspiron E1505 Notebook
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
Dell E1505 Intermittent display loss
When you click on Power Options, the power options screen will open. Here you can select a power plan, change plan settings.
When you click the Change plan settings option below any of the listed power plans, the Edit Plans Setting screen will open allowing you to change when the computer should turn off the display and when to put the computer to sleep, as well as the brightness setting of the display.
Turn off the display = Never
Put the computer to sleep = Never
Jan 07, 2010 | Dell Inspiron 6400 Notebook
My normal browsing of the internet works fine. But I play world of warcraft. Here for the past few days I have issues with my monitor just going to sleep for no reason. I have to shut down my comp and...
Have a look at your power options through control panel.
Set the computers display, hard drive to never turn off. also disable sleep mode.
If you have all these settings already set to this then whoever told you that the graphics card is overheating could be right.
The only other thing i could suggest is to update you display drivers through the manufacturers website.
Good luck.
Nov 16, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Our Brother Intellifax 3800 will go to sleep and ignore attempts to send or receive faxes. It will take a docment into memory and go to sleep and not send it or the phone will ring with an incoming fax and...
i don't have the owners manual handy, but i'm quite sure you can disable the sleep mode by pressing a couples of buttons on control panel. that procedure is in your owners manual on the same page as setting sleep time.
hth,
razors
Mar 16, 2009 | Brother IntelliFAX 4100 Laser Fax
A fully charged Toshiba Satellite M305D-4831 has a nasty tendency of running the battery down when it is put to sleep and hibernation. It is worse when in sleep, as I lose nearly half of the charge in...
If you go to control panel + power settings you can configure and adjust how your power gets distributed when in sleep mode etc. This may not totally fix your issue as it will alleviate the loss of power. I would first see what type of life the battery is supposed to have and if you are not satisfied your best bet is to replace the battery with a longer life. Goof luck and please let me know if you need any assistance with that.
Mar 11, 2009 | Computers & Internet
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Can not recieve Faxes
These machines goe into sleep mode automaticly and should exit when they detect a ring.
You MAY have a problem with your main board.
First make sure your phone cord is plugged into the correct port. There are two, line and ext. It must be plugged into line.
You can try a factory reset if that doesn't work. Unplug unit, hold menu button, plug back in and wait for lights to blink and display to read Maintenance.
Press 0 and 1
Now press 99
Now try sending to the machine again.
If this doesn't work, you likely need the unit serviced.
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
Dell Inspiron 6400 Notebook Logo
196 people viewed this question
Alun Cox
