Question about Whirlpool Duet GHW9150P Front Load Washer
Kenmore washing machine he3
Having similar problem. clothes still have water after spin. Cleaned out filter. belt dust everywhere and cut marks in back of rear tub.
pulley quite loose in all directions even when tightened. (ie when turning it has free play of two inches or so....I suspect some is necessary)
but is also loose into and away from the tub. so when I installed new and tighter belt it pulled the pulley into the tub.
do I need new basket as well as pulley?
why doesn't pulley have a self-centering feature.
is this common with this product?
thanks for any help you can provide, you seem to be the most knowledgeable of all the responses I have seen
Randy
  • louielui Jul 01, 2008
    as an addition to my previous post......the pulley gets pulled TOWARDS the tub and the belt rubs the rear of the tub when I hand spin it to center it.
    Also, I just found out that the product numbers for the belt and the pulley have changed from the original repair parts list which came from the manufacturer. Does this mean that they have found some problems with the original design and changed it a bit?
  • louielui Jul 02, 2008
    Thank you reg501. I'll order new pulley today!
    New Friend:
  • 3 Answers
I have a Whirlpool Duet HT washer [12-4-2003] and I'm on my 3rd pulley and 4th belt. I am convinced This is a inherent design flaw. I've used Loc-Tite and the nut loosened, but the last time I used gorrilla glue. The nut didn't come loose but the pulley failed and now I need giant vice grips or I may have to cut the nut off with my Dremmel. My hypothesis is when the drum is overloaded it puts stress on the shaft/pulley connection and the softer metal gives way. Over time the key becomes rounded and the pulley starts to wobble, thus leading to belt failure. My next version. Im considering drilling into the shaft and installing a cotter pin to keep the nut from backing off. Either way the problem originates with the pulley design.
PS. I will never buy another whirlpool product. kenmore washing machine he3 - 070498b6-8a05-400f-aab6-d2f7fbf10685.jpg
Posted on Apr 20, 2013
  • 413 Answers
The basket shaft is made of hardened steel, whereas the pulley is made of aluminum. It is unlikely the shaft is damaged in any way. It is not uncommon that the pulley may fail with hard use and/or the nut will come loose causing the damage you describe. Part numbers are in a constant state of flux. The design may not necessarily have changed, the manufacturer may have discovered that a similar design used on other models will work on your machine, thus saving the manufacturer money on producing similar parts.
The pulley should fit tight and snug with no play whatsoever.
Unless the tub bearing has failed, you should be able to install a new pulley and nut to get your machine operating again. I strongly recommend applying blue loc-tight to the nut to insure the nut will not come loose in the future.
Note: when tightening the nut, use a block of wood between the pulley and tub to prevent injury to your fingers.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 02, 2008
  • Richard
    Richard Jul 02, 2008
    You stated something about belt dust..I would recommend a new belt also.
    Regards,
    reg501
Washing machine won't spin clothes completely always have to run spin 2nd and sometimes a 3rd time...code says F2 I don't know what that means
Hello, Welcome to FixYa. To address your question, the F21 indicates a long drain time has been detected. What that usually really means is the pump filter is clogged. Click on the link or alternatively copy & paste my link below and you'll find detailed guide on what to do. Good luck. http://www.fixya.com/support/t7710198-code_f02_washer_will Regards, Macmarkus :)
Mar 30, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Will not spin during any cycle w/ or w/out clothing inside
that sounds like something else, I had a similar problem yesterday, the washer would stop after a few mins, I traced the fault to the water hoses, it was plummed in with a hot water feed that can get dirty over time. this had blocked the inline fiter stopping water getting into the machine, if it does not fill within three minutes it can cancel, I cleaned the filter and was out in 10 minutes.
Apr 13, 2009 | Washing Machines
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Machine not draining
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore he3
The Belt in the back has come off. I am dealing with the same issue now.
Jul 12, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Flashing F-9 and beeping
Check that the filter is not clogged.
Disconnect AC FIRST........******
open the bottom access panel , (3 screws on bottom lip)
remove panel
open the large filter in the center, very apparent
be prepared for water, have mops ,buckets rags, pans ready.
clean and remove all debris.
see if anything when up into the small pump area too.
spin the pump propeller and make sure it spins free.
if you find nothing but water then the main large hose in the center may be clogged, that will take some work to disengage the clips and to reinstall.
Jan 26, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Drain & Spin issue
Have you checked your water pump? Sometimes this is an issue of the strainer being plugged as well. Do you get any flashing error messages on teh screen?
Jan 14, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
251 people viewed this question
Dan Webster
Dan Webster
Sal De
