Question about Whirlpool Heating & Cooling
I have a new dehumidifier and I have attached a garden hose so it will empty in a sink on a continuous basin but it fills the bucket and shuts off. What can I do to have the water go thur the garden hose?
    Sergeant:
  • 225 Answers
Hi Thomas,
Is there a blanking plug that needs to be moved from one position to another, to divert the water from the bucket into the hose?
The instruction manual might tell you what you need to do.
I hope this helps. If I've "fixed ya" I be grateful for the rating, and if not please add a comment with your extra information and I'll try to help some more. Thanks, D.
Posted on Jul 01, 2008
Shuts off and light blinks looks like a water bucket that flashes
Check the wter tank it must be full and needs emptied before the unit will continue to run. If your runnig a drain hose, then the hose may be plugged or the float switch for the bucket is either hung up or malfunctioning.
If this was helpful a vote with the thumbs up would be greatly appreciated for the free advice.
Thanks and if you need more let me know.
Aug 23, 2011 | Sovereign ARP-1000E Air Conditioner
What do I have to do to connect a drainage hose to my 45 pint haier dehumidifier?
1. Remove the plastic screw on cap for the right rear side of the dehumidifier. (Keep the rubber insert well for future use)
2. Using a 40" long section Garden Hose (you furnish) , screw it to the direct drain opening. Be sure the female hose connection has a washer insert in it, If not, it will leak.
3. Position the dehumidifier as close as you can to the floor drain.
4. Position the open end of the drain hose directly over the floor drain & start the unit.
When the direct drain feature is no longer being used. Plug the Open end of the hose with the rubber cap provided. And water will then drain into the bucket.
Hope this helped you. Please let me know. Thanks.
Jul 11, 2011 | Heating & Cooling
Have connected the internal tube to self-drain, but it does not by-pass the internal or external bucket....Please help, as i would like to drain automatically to the outside, without using or emptying the...
The drain tube/hose can only be used in Dehumidifier Mode. The drain hose can be connected to a garden hose, but the hose can not exceed 40"in length. As, it relies entirely on gravity to drain. In addition, the warm air exchange hoses must vent inside the room when using Dehumidify mode.
, using it during air conditioning mode, would not be feasible.
Jul 09, 2011 | Danby DPAC7599 Air Conditioner
Dehumidifier keeps shutting down already cleaned air filter and emptied bucket
Your Dehumidifier may have a low pressure switch or a compressor hi temperature switch, if the system is low in freon it will shut the system off to keep from over heating the compressor.
Jun 04, 2011 | Haier Heating & Cooling
Not draining from the hose. Pail filling up with water
You need to check the hose and the outlet it's connected to on the dehumidifier for clogs.The dehumidifier will divert the water to the bucket, if the aforementioned is clogged.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool Heating & Cooling
I have a HONEYWELL dehumidifier (30 pints) and I would like to set it to drain directly. I hooked-up a hose to it and ran it in a drain. but it don't seem to work, the bucket still fills up and then...
Louis, some models do not require that the bucket be placed back in the unit, if a drain hose is connected. You'll need to check your Owners Manual on that. The other thing is, where the hose is connected may be clogged and is forcing the water to go into the bucket. Disconnect the hose coupling and check for clogs. Also, keep in mind, the dehumidifier does not have a pump. It relies on gravity to move the water through the hose. If the hose is longer than 5 feet, is kinked or not sloped downward, it can't drain the water.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
Everstar MPM 08CR BB4 P1 light is on and unit wont start. I emptied the bucket, I drained the hose inside bucket area and put back where it wouldnt be in the way of the bucket, I unplugged and plugged back...
"The black plate with floater in the bucket" is what signals that the bucket is full of water. So if it isn't in the right place then you will get "P1" (Problem 1 which means bucket is full). The "black plate" needs to flop down inside the bucket for it to register as empty. When the bucket fills the floater makes the plate go to the top and it shuts off the unit.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
Jun 14, 2009 | Danby Portable Air Conditioner
I have a portable air conditioner and the water condensation tank fills in about 4 hours of constant use. Is there any kind of portable water tank that I could attach to my unit that would allow me to...
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Jun 11, 2009 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
