Recently bought a Humax LU26-TDI 26'' LCD TV, seems to work intermittently then screen goes black but sound is still working can you help
SOURCE: 60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Posted on Jan 27, 2008
  • 3 Answers
SOURCE: lcd tv screen stays black, but with sound
just open up the tv 2 the main bord then look for a littler green button press it and then plug it in and it will work i did it 2 mine
Posted on Mar 23, 2008
Tech4lfe
  • 42 Answers
SOURCE: when i switch my samsung
Sounds like you need an inverter board which is the power supply for the screen lights. I tried to look up the part but samsung dosen't have a service diagram posted for it yet. Since it is so new you may want to find a samsung authorized service center because if the part is not available yet Samsung will have to solve the problem.
Posted on Jun 27, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
HeXx13505
  • 65 Answers
SOURCE: Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Posted on Mar 27, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
TV SYMBOL COMES ON TV GOES BLACK NO SOUND OR ANYTHING HOW TO REPAIR THIS
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
Jan 16, 2016 | Hisense Televison & Video
Hi, I have a 32LG3000 HD tv with software version 3.47.1. I just bought a Humax FoxT2 HD free view box but when connected via hdmi to the LG tv a message briefly comes up on the tv saying invalid format...
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
pete
Nov 11, 2010 | LG 32LC7D Television
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Jul 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No picture when turned on - sound ok
I think that you should try playing around with some of the plugs
Jun 21, 2009 | LG 26LC2D 26 in. LCD Television
Sharp Aquos 32" LCD Screen goes black!
Main digital board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 05, 2017 | Sharp Aquos LC-26P70E 26 in. LCD...
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
