Question about Sony MDR-7506 Professional Headphones
Chord needs changing but screw won't come out
Anybody open their headphones and find the screw stops at a certain point. I'm not sure it's supposed to do this and I should pry it or if the screw is screwed. I've never opned them before (MDR7509) so there's no reason this should have stripped screw. Help pleas.
Well, I got it out but what a pain. I had to take a tiny eyeglass repair screwdrive and dig down next to the screw and leverage past whatever threa of impediment. Then it finally came out. Origially I didn't know if this was manufactured to stay in so some of my earlier "prying" attempsts left some marks. Don't pry the outer cover off if you have this problem--you'll break something. There's an idiosynchracy with the screw which also happened on the other side cup.
Posted on Jul 02, 2008
I have ecko unltd headphone and when I bent the chord of them the music stopped but when I bend them the other way they work
There is a broken wire in the lead. You can replace the cord or locate the broken wire/s break the lead at this point and rejoin the wires. Make sure the joins do not short against each other. This joint may look a bit untidy.
Jan 08, 2013 | Audio Players & Recorders
My urban beatz tempo over ear headphones won't work they play no sound at all connected to my I pod or computer it just happened out of nowhere?
I have that same problem and I need a answer but I walked in m class and the chord hit the table and it just stopped mine is about a week old also
Sep 08, 2012 | Audio Players & Recorders
My headphone cord was cut how do I repair?
Hi, it all depends on where the damage was from, either from the top close to where the ear speaker is,or just from the body of the cord..
From the ear speaker area, you might need to do some soldering...
Get a screw driver,remove the forms from the ear speaker, unscrew the screws off, and open...if there is any cut wires,take the soldering iron and re-solder it... That will do..
If it's from just body of the chord area just get a sharp object, peal off the rubber surface covering the wires inside,and joint all cut wires,with color codes, and after doing this,use a tape to cover it up...And your done..
After all this exercise.still no sound, you will need to test if the ear speakers are working well and also you might need to replace your chord with another one...
Hope that helped.
May 16, 2011 | Skull Candy Audio Players & Recorders
Sound in one headphone keeps going off and on, moving the wire around can fix it temporarily but is very annoying
You have a break in the cable. You don't say in what area it's in, so I will have to give you 3 ways of clearing the fault.
1: Break in, near or around the plug. The best solution is to cut off the plug making certain the break area goes with it. You can then fit a new 3.5mm plug. If you need advice on how to do this let me know.
2. Break halfway to 2-thirds along the cable. Again cut the cable to a point clear of the break, again fit a new plug. To extend it you can purchase an extension headphone cable from any hi-fi shop.
3. Break to close to headset. In which case you will need to replace the entire lead. To do this you need to open up the headphones. Access is obtained by removing the pad(s) and any foam. You might need to force the foam off. You can glue it back on afterwards. You should then see screws to open it.
Fitting new plugs or attaching the wire inside will require the use of a small soldering iron.
Apr 01, 2010 | Sennheiser HD 25 SP Consumer Headphones
The left channel has stopped working on my AKG K66 headphones. I have checked the plug, and there doesn't seem to be any damage to the chord. I want to check for an unsoldered wire in the speaker, but I...
Most headphones are opened at the bit that goes to your ear. Remove the pad and foam and you should see screws. You may have to force the foam off, but you can allways glue it back on when done.
Dec 17, 2009 | Audio Players & Recorders
Wher are the caps that cover the air/fuel mixture screws?
the cap is right in between the carb heater nut and the big philips head screw
Jun 07, 2009 | 1981 Yamaha XS 650 H
2000 Lincoln Navigator, How do you get the heater core out?
the door squeezes in on the side to open all the way to reviel the screws
Dec 24, 2008 | 2000 Lincoln Navigator
Change ear pad
I hope below exploded view will help you how to open moz-screenshot.jpgMDR-V700DJ headphone.
Nov 03, 2008 | Sony MDR-V700DJ Professional Headphones
Sandisk MP3 player SDMX1 - bad headphone connector
I have the same trouble. I ended up taking the 3 screws out, then I used a flat screwdriver to pry open the end pieces. Note from the top that there is a line where the end pieces connect. Pry off both end pieces - then you can separate top and bottom. HOWEVER, once you get in, it will be apparent that this is not very hacker friendly in there. There is a daughter-board with the microphone and headphone adapter and its epoxied in there. If anyone is successful in determining how to fix the headphone jack, please add!!!
Dec 26, 2006 | SanDisk SDMX1 MP3 Player
Sony MDR-7506 Professional Headphones Logo
153 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
