Question about GPS
My Garmin 760 can no longer be used on battery power alone. It only works with the power cord.
  • 250 Answers
Hi IlliniGuy,
It sounds like the battery in your Garmin 760 has failed.
Rechargeable batteries have a limited lifespan. The amount of time you can expect between charges will decrease until the battery eventually does not hold a charge. It sounds like you have reached that point.
Although the battery pack in most MP3 players is not generally considered to be end-user serviceable you should be able to get service on the battery by contacting Garmin. If the unit is out of warranty there would normally be a fee for that service. Or, if you have experience repairing electronic devices you may be able to purchase a new battery and replace it yourself.
Hope this helps,
"Go Ahead. Use Us."
Posted on Jul 01, 2008
I have a Garmin nuvi 255w GPS. Recently, the cigarette lighter adapter cord began to fray, causing the unit to flip back and forth between running off the battery and drawing power from the cigarette...
You must buy the Special Traffic cord to receive the will have 2 lights to it to let you know that it is working..... just a regular cigarette lighter adapter plug will Not work, you need the Traffic Receiver cord.
You can get them on the Garmin site
Nov 05, 2010 | GPS
My Garmin Nuvi 760 screen goes black after 8-9 seconds. I have replaced the fuse in the charge cord. Someone recommended that I remove the battery and turn the power button on for ten seconds to reset the...
Do not open the nuvi, the garmin site recommends the following method instead:
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on
If this fails to solve the problem, contact "SUPPORT" at
Please rate this reply if helpful - good luck.
Jun 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin Nuvi 760 will not power up either on the charging station or hand held. When plugged into AC outlet the charging cord flashes in intervals of two. Any idea what could be happening?
Replacing the nuvi 760's battery is actually not all that hard as this video demonstrates:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi 760 is back up and running smoothly.
Jun 07, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Won't hold a charge.
will not turn on with or with out power cords garmin 760
Jan 04, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
I keep getting low battery message while my 750 is plugged in?
I'm still not 100% clear about why this is an issue (I'm having the same problem with my nüvi 760), but . . .
If you connect the Garmin to a power source via the USB port and leave it for a good long time (overnight) it should recharge even though the unit had been refusing to accept a charge through the normal power cord.
Jun 07, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Won't switch on
I had a similar situation. My 760 could not be switched on, despite a fully charged battery. The hard reset procedure (power button held for 8 seconds) fixed my problem.
Apr 07, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Charge garmin 750
My 760 was like this, I think I'd let the battery run totally flat. I was able to get it to power up, then charge, using a mains charger, thankfully I'd bought one, they aren't included as standard.
Jan 01, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I have a Garmin Nuvi 760. The end cap which screws in and holds the fuse in for the traffic receiver power cord is broken. Anyone knows where I can get a replacement part without buying another power...
This is a known problem with the 760 traffic receiver power cords. Call Garmin Customer Service (you may stay on hold for 20 minutes or so). When someone answers, explain the problem and they will most likely send you a replacement screw cap and fuse assembly for free.
Jun 12, 2008 | Garmin GPS
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
89 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
