Several problems. TV won't shut off unless you unplug it. Flashes intermittently between white screen and black screen. DVD does not work other than the open/close function of ejecting a CD/DVD. No input selection from either the TV or remote buttons. None of the buttons do anything.
  • 8,617 Answers
Need the model number in order to even begin to offer a suggestion. Please respond to this same post with your model number
Posted on Jul 01, 2008
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
LG 37 TV WON'T STAY ON
Try changing the input device to something you are sure, works such as a DVD player. If it is same, there are leaky/dry capacitors and/or dry solders. Please refer it to a qualified service technician.
Aug 02, 2012 | LG 42LC2D 42 in. LCD HDTV
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
TV is connected to cable; when we have a picture it is terrific. There are several times during the day when we have audio but screen is black. Unplugging and waiting an hour or more sometimes helps but...
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Nov 14, 2010 | Sansui HDLCDVD325 32 in. LCD TV/DVD Combo
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
My plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
Apr 10, 2009 | Philips Magnavox 42MF521D/37 Television
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
RCA 27V530T 27" TV
You may have a couple of problems here.. It souds as the tuner is intermittant and a common capacitor in the power supply is bad.. Depending on the chassis, and I think its a CTC 185 I think if your handy you can get a fully repaired board for this set at http://ptscorp.com. If you have no tv reoair exoerience, you should give back the set and be done with it. Its all up to you. This set will most likly cost 200 to 225 to have a shop repair it and I think itys not worth that. Good Luck
Oct 08, 2006 | RCA 27V530T 27" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
