Question about Maytag EPIC MFW9700S Front Load Washer
Maytag Washer-EpicZ frontloader - error code F20
What is this, and how the heck do I fix it. HELP please.
Thnx
  • 750 Answers
Hi cybileyes,
Are you still having problems since July 01, 2008?
If you have a code the best and first thing you can do is unplug the washer for 5 minutes and then restart it the system should reboot or reset!
let me know what happens for you.
Bless You
HUUUM
Please remember to give a rating before you leave.
Thank You
Posted on Sep 22, 2008
My washer also just flashed the 01- F symbol and I was completely shocked after only owning it for 8 months. I tried everything but unplugging it and so I did. After about 8 mins I plugged it back in and wa- la.... thus far it seems to be working. *knock on wood*
Posted on Sep 26, 2008
WE STOPPED THE WASHER TO ADD ADDITIONAL ITEMS AND IT WILL NOT WORK NOW. WE GET A ERROR MESSAGE F-02 I DO NOT HAVE A MANUEL
Posted on Sep 23, 2008
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
I have a 4000 Series Maytag Frontload Washer that is blinking with a F-20 error code. I am trying to find out what this means.
The F20 code usually means a washer fill problem. It could be low water pressure or no water pressure. Check that your water valves are open on both the hot and cold inlets. Check the hoses for kinks or damage that interrupts the water flow. Check for debris in the inlet filters and clean the filters. Some anti-flood hoses can close their internal valve if the water pressure builds up. This could cause the machine to see no water pressure. What is your water pressure (it should be above 10 psi)? If you have a water well, this could could give low water pressure to the washer and trigger the error.
Replace the hoses if needed. If you have a High Efficiency washer, make sure to use HE detergent. Excess suds could cause the incoming water flow to be judged as low.
See http://maytag.custhelp.com/app/answers/detail/a_id/2887/~/display-shows-f20-or-fh---front-load-washer for details.
I hope this helps.
Jun 28, 2011 | Washing Machines
I have a Maytag EpicZ. It is giving me error code F20. What do I do?
its a reaction code try unplugging the washer for ten minutes then try it again let me know how it goes
merry christmas
Dec 21, 2010 | Maytag Washing Machines
I have a may tag epicz washing machine that continuously has the F20 eerier signal. We checked the hoses, drainage and filter. There is plenty of water, in fact the cloz are drenched dripping wet when...
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Aug 23, 2010 | Maytag EPIC MFW9700S Front Load Washer
Codes F-21 And F-33 are showing up
this error occurs if the touch-pad/led assembly is not able to transmit/receive data to/from the central control unit (CCU) 1 check the touch -pad/led assembly by selecting different cycles and changing the modifiers and options available to confrim the touch-pad/led is responding. 2 unplug washer or disconnect power. 3 check wire harness connections to the touch-pad/led assembly and central control unit (CCU) now to the f-33 code system leak if after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR if the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. press PAUSE/CANCEL twice to clear the display. possible causes/procedure 1 check for crack or holes in the washer tub and pressure switch hose. 2 replace components if necessary good luck
Feb 16, 2010 | Maytag EPICz 3.7 cu. ft. Washer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
1,253 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
