Question about Toshiba Qosmio G25-AV513 Notebook
Qosmio G25-AV513 Case
Hi!
I also have an overheating problem with a Qosmio G25-AV513. I would love to know how to open the case.
Thanks!
I would like to open the case of my Qosmio G25-AV513 notebook to thoroughly blow out the dust and clean the CPU heatsink/fan. Is there a specific manner to opening the case?
Post Solution Work Queue --> Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Mar 12, 2008
mccbala
Rank: Master
Rating: 80%, 11 votes
Yes.. First of all you are entitled to open the case only if your lapotop is not covered by any means warranty.. If you open it when it has a warranty, the warranty becomes void.. and moreover there are many complications n opening it.. so i suggest you to give it to a system engineer.. but if u want to do it by urself.. i shalll tell u the steps.. mail me..
I have not verified this myself yet, but I will this week. Here is the link: http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/comment-page-1/
Click on the appropriate laptop. The pictures are very helpful when clicked on.
Posted on Jul 25, 2008
"A problem with the cooling system has been detected."
have you tried blowing out the internals of the notebook with compressed air? if the laptop is not actually overheating it could be a sensor problem. if that's the case you can more than likely disable these warnings in bios. hope this helps!
Jan 27, 2012 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
Hi i have problem with toshiba qosmio g25-av513 when i power on its show clear QOSMIO monogram and then start show saverl difrent colurs lines i try with external monitor show same .pls help me to fix this...
You can try downloading the most recent video drivers from the nvidia web site and installing them.
Other than that you would probably need to contact Toshiba tech support. Based on the information you provided it sounds like your video card is having a hardware issue. It's the reason you see the same lines on both monitors.
Apr 10, 2011 | Toshiba Qosmio G25-AV513 Notebook
Pci express error
Means you network card has somehow got weged out and its halfway in, halfway out.
You would have to open up the laptop and make sure everything is pushed in.
Dec 31, 2009 | Toshiba Qosmio G25-AV513 Notebook
Verticle stripes on monitor--Toshiba Qosmio G25-AV513 PC Notebook
Following factors could be causing this problem and solution as well:
1) Cable Cut: check is to see if the cable between the screen and laptop is pinched or cut. Every laptop has this wire that runs through one of the hinges
2) If this problem temporary i mean for some seconds then it could be a short signal cut problem to screen which causes screen distortion
3) Connect an external monitor and restart the laptop. If you see the same strip on the external video, then that is the motherboard or the video card problem in case you have a video card on your laptop apart from integrated graphics chip
Nov 18, 2009 | Toshiba Qosmio G25-AV513 Notebook
No hotkeys on my G25-AV513
Usually on Toshiba notebooks, they have a memory resident program on their call fkeys. If it isn't installed on your computer, you can download a new one from Toshibas support website.
Jul 20, 2008 | Toshiba Qosmio G25-AV513 Notebook
Qosmio g25-av513 disassembly
Hi Paul have a g25-av513. First disconnect and remove both hard drives and the battery. In the battery compartment there is a small screw you need to remove and in the hard drive 2 bay there are 2 f8 screws that need to be removed as well. In all there should be 17 screws that need to be removed before you can pop the back cover off. When removing pay close attention to the connectors attached to the underside of the back cover. be careful not to pull to hard or you may tear the connectors which are very thin wires. First you have to remove all the screws on the underside of the laptop. The screws are marked f8's and f16's the longer ones are the f16's of course. I have taken mine apart several times already due to a boot up shut down issue which I believe is related to the modem board underneath hard drive 2. It seems that when ever I disconnect and reconnect this board my power shut down issue disappears. If it happens again I'm going to remove i all together and see if that takes care of my problem.
Jun 01, 2008 | Toshiba Qosmio G25-AV513 Notebook
Removing dust
Mar 12, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
322 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
