Question about Pioneer CDJ-800MK2 Turntable
Cd malfunction hi im having problems with mi cdj800mk2's , when its playing a track sometimes it jumps back the the ending of the previous track . igot the lens clean and it still happens
  • 1 more comment
  • DJ_Protege Feb 02, 2009
    I am also having this issue with the 800's... will be playing then head back to the last track killing the music completely. it wont let me start the track up again until i eject and re-insert the cd...
    coudl this be an over heating problem or a short fuse??? any help would be great.
    thanks
  • wessel317 Feb 18, 2009
    Same story with mine. It just jumps back to the last 10 seconds of the previous track for no reason. Also totally random, i haven't found any pattern or logic in it...
    Does it happen with burned CD's or also with original cd's? And what are you using to burn the cd's?
    I burn all my cd's with itunes on apple and I have a slight suspicious that the way i burn the cd's have influence on this. It is the only thing I can think of... How is that with you?
  • 515 Answers
Lens cleaners aren't enough. You might have to take it to a service center to have it opened up and professionally cleaned.
If there is no damage to the cd traverse assembly, then the issue might be with either the quality of your burned CDs, or method used to burn.
I always tell people to burn at slow speeds - 4x is ideal. Yes, I know it's slow, but it will burn your cds at a better quality.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
My stereo system keeps skipping tracks whilst playing can you help?
The lazer is going on it. End not reading the info on the disc properly,
Oct 29, 2012 | Audio Players & Recorders
Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
May 19, 2011 | NAD C542 CD Player
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
Player jumps back to previous track for no reason
Have you tried cleaning the lens out? Invest in a good quality CD cleaner. IF this does not solve your problem, then you more than likely have damage to the reader, and will need to be replaced.
The part can be found here: PIONEER CDJ PART
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Feb 14, 2009 | Pioneer CDJ-800 Turntable
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
My tracks don't play in the recorded order, list I made them.....
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged,
and if track doesn't jump or restarts in middle of playing back then cd player is just fine,
Please check cd creator software settings.
Dec 18, 2008 | Sony CDX-MP40 CD Player
SONY RXD10AV.
haresva mi stereo uredbata as tursia takava sony rxd10 sony rxd9 skupe xakera.1 bulgeria
Jan 13, 2008 | Sony MHC-RXD10AV CD Shelf System
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
Pioneer CDJ-800MK2 Turntable Logo
122 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
