Question about Samsung RS2630SH Side by Side Refrigerator
We have condensation inside our frig
Samsung model RS2545SH side by side has alot of condensation inside and leaks some water onto the floor
  • 3 more comments
  • thanks_fella Jul 03, 2008
    Water inside the fridge, leakin near the assy tank water (white pipe behind the vegetable tray); water dripping also on the bottom right front end.
  • Howdy 1 Jul 24, 2008
    Same Same, Bought at CostCo. Don't see any recall info posted. Everone should start calling CostCo and inquire about this.
    Costco.com Member Service:
    800-955-2292
  • Shan_m Apr 06, 2009
    I have the same issue. The fridge temp shows 53, but varies couple of degrees up and down. The fridge compartment had a water leak.
  • Anonymous May 01, 2009
    Water leaking from the bottom anti-condensation knobs on the bottom of the frig. No one can figure out the fix.
  • lifesabeach7 May 14, 2009
    yes, my fridge is leaking inside and out to the floor, I have a towel soaking it up and have to change it out daily.  sucks, no one on my island knows how to fix it I purchased it 3 years ago from costco when I called they basically told me I was SOL. and to call samsung repairman who is overloaded with jobs, guess I won't buy this brand again.
I fixed this issue!!!
Water was leaking from inside my fridge. This was happening because the condensation drain was iced over. Where is this drain? To get to it, first remove the crisper bins from inside your fridge. Then remove the back panel by removing 6 screws: 2 at the bottom corners, two on the sides, and two behind each light bulb. The panel might require a little effort to unstick from the back of fridge. After removing the panel, you will see the condensation coils (they're cold). You will also find some ice and water in a collection area below the coils. Normally, water falling from the coils will land in the collection area and pass through the slits at the bottom to a pan below your fridge where it can evaporate. In my case, ice was blocking the way causing the water to backup. To fix it, I removed the water with a rag, then used a hair blow drier to heat the collection area and melt the the ice (including the ice out of site in the drain). After a few minutes, I was able to pour water into the collection area and it passed through!
This is a pretty easy fix. All you need is a screw driver, a hair blow drier, and about 30 minutes.
Posted on Jun 13, 2011
Same water leak. Just ordered valve water assembly. I observed it for three days water dripping from the valve water assembly. I hope to install it today and observe again. I will also try to clear up any ice on the drain pipe to the drain pan at the bottom underneath the fridge.
Posted on Nov 18, 2009
My fridge leaks water every three days.
Mine had an issue with the drain from the freezer section. When it went into a defrost, the condensate water would miss the drain and fill the frig then onto the floor. The other issue can be the condensate pan that collects the water may be overflowing for some reason. Look for that as that could be the simplest fix to start with.
Apr 28, 2018 | Refrigerators
Water in the bottom of the frig, right side.
Find the condensate drain in the bottom of the frig and clear it
Jun 01, 2010 | Samsung RS2630SH Side by Side Refrigerator
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Why is my whirl pool frig leaking onto the floor and how can i fix it
Frost buildup inside the **** tube that leads from the evaporator coil to the bottom for defrost condensate tray is plugged. Try giving the unit a manual defrost by unplugging and leaving the doors open all night 12 hours. If the problem comes back you may have to take the cover off the evaporator coil and use a turkey baster to force warm water to flush out the tube.
Mar 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ford Fiesta 2003 1.3 If I run the aircon water leaks onto the floor of the drivers side (by the pedals, alot of water.
In the dashboard,set down low is a driptray.It collects water that comes off the aircon.It has a hose (sometimes 2) that drains the water out of the car via the firewall so it drips onto the road.This is blocked or the tray has a buildup of gunk.The hose is about 1/2 inch thick.If you lay on the floor where it leaks with a torch you should find it.Or look in the engine bay,just to the left or right of centre(which side leaks?)and backtrace it into the car.You may find the inside hose has fallen off allowing the water to drip inside.Hope this helps you
Jan 01, 2010 | 2007 Ford F
Frig Freezing EVERYTHING!
Your refrigerator has electronic dampers that may be only stuck. I think it would not hurt to defrost the refrigerator and lets have a look at those damper motors and see if they are responding to your control settings. Let me know, Sea Breeze
Jun 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Kenmore side-by-side 106.52764100 Frig leaking water
Do you have a Dog ??? I had a customer who had a problem like this once.................Only to find out in the middle of the night the dog jumped up and with his nose pressed the water dispenser..If not plz check inside the freezer and see if your drain is clogged pull the bottom drawer out and look on the back wall..
PS: the pan even with a clear drain will not fill up the condenser fan with the heat from the condenser will evaparate the water after a defrost cycle
Feb 23, 2008 | Refrigerators
Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Sep 26, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS2630SH Side by Side Refrigerator Logo
1,063 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
