Gateway GT5228 PC Desktop Logo
Posted on Jul 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory Card Reader
When I stick my SD card in my computer nothing happens. Where are the pictures on the card located? I am using windows Vista.
  • Anonymous Jul 07, 2008
    driver
Anonymous
Level 2:
Scholar:
  • Expert 60 Answers
  • Posted on Jul 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
60
Questions
0
Helped
55980
Points
178
You should find your SD card listed as a drive type 'Devices with Removable Storage' in Windows explorer. To find, click on the Windows Start button (lower left-hand corner of your screen) and click on 'Computer' on the right-hand side of the menu that pops up.
A quicker way to bring this up is to press the Windows key on your keyboard (usually located between the Ctrl and Alt keys on the left-hand side) and the letter 'E' .
Once open you should see your SD card listed under drive type 'Devices with Removable Storage'. Double-click on it to open and see the photos on the card.
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
SD memory card reader
Many HP and Compaq computers come with memory card readers preinstalled.Figure 1: Memory card reader (yours might be different)
12_26_2011_1_43_52_am.jpgMemory cards are used primarily for importing pictures from digital cameras, but they can also be useful for sharing pictures and files. The following list shows some common types of memory cards:
  • CompactFlash I
  • CompactFlash II
  • IBM Microdrive
  • Secure Digital (SD)
  • mini-SD
  • MultiMediaCard (MMC)
  • Reduced size MultiMediaCard (RS-MMC)
  • MultiMediaCard Plus (MMC plus)
  • MultiMediaCard Mobile (MMC mobile)
  • Memory Stick
  • Memory Stick Pro
  • Memory Stick Duo
  • Memory Stick Pro Duo
  • SmartMedia
  • xD Picture Card (xD = extreme digital)
NOTE: If your computer came with a 6-in-1 card reader by KYE and was purchased before summer of 2003, update its card reading firmware by using the HP Download Web Page (in English) for your computer model name. Updating the KYE firmware allows bad blocks messages to be displayed.
A high capacity SDHC card locks up or the SDHC card cannot be readMany models of PC card readers do not work with "high capacity" formats. For example, a memory card reader capable of reading a 1 GB Secure Digital (SD) card might not read from a 16 GB SDHC card.The computer might lock up when an SDHC card is inserted into a card reader that does not support SDHC. To immediately fix the lock-up, double-click the Safely Remove Hardware icon, (in the notification area in the lower right corner of the screen), select the USB card reader, and then click Stop . The card reader will not work until the computer is restarted. You can now safely remove the memory card and use the computer for other activities.To use your higher capacity memory card without locking up the computer, do one of the following:
  • If you are using the card in a camera or other device, you can attach the device to the computer using a USB or FireWire cable. When connected, most devices appear in Windows as a Removable Disk and can be used in the same way as the card reader.
  • Use a USB memory card reading device that plugs into any open USB port. Make sure the USB device can read SDHC. These devices are inexpensive and can be used in any computer that has a USB port.Figure 2: SDCH to USB card reader adapter
An SDXC card cannot be readMake sure the card reader specifically supports the SDXC format. You can access the SDXC card by using an SDXC compatible USB reader or adapter. Look for an SDXC logo on the device or check with the device manufacturer for information.
CAUTION: Never format an SDXC memory card in a non-compatible device. Doing so will make the memory card incompatible with SDXC devices because it will erase the data on the SDXC memory card and format the card for a different file system.
Card reader stops working after using Safely Remove Hardware
CAUTION: Do not insert or remove memory cards while the light on the reader is flashing. Doing so might cause loss of data on the card or might permanently damage the card reader.
The following steps explain how to use memory cards in a card reader:
  1. Insert a memory card when the light on the reader is not flashing . You can have a memory card inserted in each slot in the card reader, at the same time.An autoplay window displays. If it does not, access the card through Windows Explorer.
  2. The memory card has a drive letter, like a DVD drive or hard drive. Use the memory card as you would use any other drive on the computer. For example, double-click the memory card icon to open a new window showing the files on the card.
  3. When you have finished working with the files on a memory card, right-click the memory card icon and select Eject . Make sure the light on the memory card reader is not on or flashing when removing the card from its slot.Figure 3: Eject feature in Windows Vista
Memory card readers are devices that use the Safely Remove Hardware icon in the notification area on the taskbar). Do not click Stop in the Safely Remove Hardware window. Doing so can disconnect the memory card reader from Windows. If this happens, restart the computer to reinitialize the memory card reader.
An alternative to restarting the computer is to use the Optimize for Quick Removal feature in Windows as follows:
  1. Open Device Manager:
    • In Windows Vista, click Start c01041253.gif , and type Device Manager into the Start Search field. Click Continueif a UAC message opens.
    • In Windows XP, right-click the My Computer , select Properties from the drop-down menu, select the Hardware tab in the System Properties window, and then select the Device Manager button.
  2. In Device Manager, click the + sign next to Disk drives to display a list of the drive devices on your computer. Memory card readers are seen as drive devices in Windows.
  3. In the list of drive devices, right-click the device that has stopped functioning to display a drop-down menu (for example, Generic USB CF Reader for CompactFlash media).Click Properties in this menu.
  4. Click the Policies tab in the Device Properties window.
  5. Select Optimize for quick removal , and then click the OK button.This setting disables write caching on the device and in Windows, so the media can be removed without using the Safely Remove Hardware feature in the taskbar. The card reader might experience a minor drop in device performance.Figure 6: Optimize for quick removal setting
Memory card icons are missing in WindowsIf you cannot access the memory card, or the drive is not listed in My Computer, use the following steps until the drive displays:
NOTE: If you are using a card reader that did not come with the computer, contact the manufacturer of the adapter for help.
  1. Remove and reinsert the memory card.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  2. Restart the computer.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  3. Reinstall each memory card device using Device Manager:
    a. Remove all memory cards, and unplug all USB storage devices from the USB ports.
    NOTE: Make sure you remove all USB devices.
    1. In Windows Vista, click Start , type Device Manager into the Start Search field, and press Enter .In Windows XP, click Start , right-click My Computer , select Properties , click the Hardware tab, and then click the Device Manager button.
    2. Click the plus sign next to Disk Drives to open the category.
    3. Right-click a "Generic" card reader device name and select Uninstall .Figure 7: Device Manager in Windows XP (Windows Vista is similar)
    1. Wait until Device Manager updates the list, removing the name of the Generic device.
    2. Continue uninstalling Generic card reader device names until they are all removed from the list.
    3. Restart the computer and use the card reader. If problems persist, continue to the next step.
  1. Try another memory card of the same type in the same slot. If this memory card works, the card reader is working correctly. Replace the original memory card. If the second memory card does not work, continue using these steps.
  2. If you are using Media Center, remove the memory card, maximize the Media Center window, and reinsert the memory card.
  3. Turn off the computer, disconnect the power cord, and press the power button on the front of the computer for five seconds. Reconnect the power cord and turn on the computer to test the card reader.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  4. Some memory card readers use support USB devices. Insert a USB device into an open USB port to test whether the card reader can read from the USB device. If the device works correctly, continue to the next step. If the USB device also fails, there is a problem with USB.
    1. Turn off the computer and disconnect the power cord. Then shine a flashlight into the empty card slots in the card reader to see if any pins inside are bent. Straighten any bent pins with the end of a mechanical pencil. Replace the memory card reader or have the computer serviced if a pin is bent and is touching another pin.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. If there were no bent pins, continue to the next step.
    2. The memory card reader software is usually set up through a plug and play process in Windows. Some computers that came with Windows XP and built before 2003 might come with separate software for the memory card reader. If so, reinstalling the memory card reader software and then restarting the computer can fix problems with the memory card driver. To reinstall the card reader driver on HP and Compaq desktop computers, see the HP support document, Using Recovery
      10 Reset the cable connections and memory card firmware:
      1. Remove the side of the computer case by unscrewing the two retaining screws on the back of the computer and sliding the side panel towards the rear of the computer. Set the panel aside.b.Find and disconnect the cable from the back of the card reader and leave it disconnected.Figure 8: One type of connection on the reader (your computer might be different
12_26_2011_1_55_53_am.jpgMake sure that the other end of the cable is correctly connected to the motherboard or an electronic card connected to the motherboard. Make sure that the unconnected end of the cable is not touching any electronics or components inside the computer, particularly the fans.Figure 9: Connector on the motherboard (your computer might be different)
  1. Replace the computer side panel and turn on the computer.
  2. After Windows starts and the desktop displays, wait about five minutes for Windows to make the necessary hardware changes.
  3. Turn off the computer and remove the computer side panel.
  4. Reconnect the cable into the back of the card reader, replace the side panel, and turn on the computer.
  5. Check to see if the drives appear in My Computer or Windows Explorer:
    • If the memory card drives appear in Windows and work correctly you are done.
    • If the memory card drives do not appear in Windows, the drive might need to be serviced or replaced.Memory cards appear in Windows but errors occur when writing or readingIf you are having problems reading and writing data to memory cards, use the following troubleshooting tips:
      • Try a different memory card of the same type in the same slot. If this memory card works, the card reader is working correctly. Replace the original memory card.
      • Some cards have a read/write security switch on the card. Make sure the switch is set to Write Enabledbefore trying to write data to it.
      • Make sure that the amount of data you tried to store has not exceeded the capacity of the card.
      • Inspect the ends of the memory cards for dirt or material closing a hole or spoiling a metal contact. Clean the contacts with a lint-free cloth and small amounts of isopropyl alcohol. Replace the memory card if necessary.
      • Make sure the memory card is supported by the card reader.
      • Make sure the memory card is fully inserted into the slot.
      • Remove the memory card when the light is not flashing and shine a light into the empty slot to see if any small pins inside are bent. If the pins a slightly bent, turn off the computer and straighten them with the tip of a mechanical pencil. If two of the pins are touching, replace the memory card reader or have the computer serviced.
      • If errors continue, replace the memory card.
32helpful
3answers
How can i recover the pictures in my SD pro duo memory card which when inserted in my Sony DSC W330 it appears reinsert the memory card which infact it is already inserted? pls help me.,what should i do?
you can recover pictures from sd card with SD Card Recovery Software like asoftech photo recovery, the card recovery software not only recover photos, but also videos, music files and other files. download the software from
hope this helps.
Why wont my computer read my SD card? i have a Samsung TL210 double view hd camera. when i put my 8gig SD card in my computer nothing happens at all i have a vista computer ok. i am 13 years old so make...
If the 8Gb SD card works on your HD camera, then the problem is with your built in memory card of your computer. Most of the built in memory cards of the computer only supports up to 2Gb.
You can actually isolate it by trying to test an SD card lower than 8Gb to your computer.
Solution for this is to use external USB SD reader that supports high capacity SD card (SDHC) or contact the manufacturer of your computer and ask for firmware updates for the memory card reader. Hope this is clear and would help you.
The driver wont install on my computer so i can veiw/copy the pictures
This could be a windows problem.
But the camera has to work as a regular USB stick. Try inserting the USB cable in the PC and see what happens.
If nothing works, consider purchasing a Card Reader. You extract the SD card from the camera, insert it into the Card Reader and copy the pictures to the computer.
1helpful
New Coolpix L20. Driver does not install with Windows Vista. Have un-installed all USB, re-booted, etc, but nothing helps. Have inserted Nikon CD and tried installing driver from there, but still...
Greetings,
I would take out the SD memory card and use it with a card reader like this one: http://bit.ly/5fruhB . You simply take out the SD memory card and put it in the card reader. Then put the usb end of the card reader into your computer and download the pictures that way.I also recommend that you download Picasa, a free photo organizer/editor for your pictures: http://bit.ly/5f6HEt This way you bypass the lousy nikon software altogether. Hope that was helpful,
Take Care,
-WN
2helpful
How do i load pictures from a sd card into computer
determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
1helpful
2answers
Windows vista not compatible with pentax optio 33l
If you're using an sd card or most other standard memory cards you can buy a card reader very cheaply and plug it into the usb of your computer, your computer may even have a reader built in
3helpful
Cannot download pictures from camera to computer
What system Are You Using? Im Using windows Seven And Vista, It Will Not Work . Just Use Sd card Reader Or Flash Usb Sd reader.
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
