Question about Sony Cyber-Shot DSC-S500 Digital Camera
How to set the time on the camera
Well I just need to kow how you can set the timer on the camera so that it will take a pic. of me and others so that no one will have to hold the camera and we all can be in the pics.
  • 78 Answers
Depends on which model you have, usually a setting in capture settings.
Posted on Jul 13, 2008
200mm pics are blurry even with tripod
Happens all the time, and for a lot of different reasons.
If a tripod isn't sturdy enough to support the camera and lens then it may as well not be there. You might want to read this article.
If your camera and/or lens has any kind of image stabilization capability, turn it off when you mount it on a tripod.
A remote release may help. But if timing isn't critical (as in landscape shots) try setting the self-timer. This gives you plenty of time to take your hand off the camera before the shutter fires.
One way to tell whether the tripod is the cause is to use an absolutely rigid support for comparison. Set the camera on a rock or stone wall or fencepost or some such and take some pictures (with and without the self-timer). You're not going for great pictures, all you want to do is get them onto your computer and see if they're sharper than the pics you take on your tripod.
Jun 25, 2012 | Cameras
I on't kow how to use the self timer on my nikon d70s
On top of the camera body, on left side(as your using it, there are 2 buttons. Not the one that says bkt, but the other one is pressed and whiloe pressed rotate the command dial until a circle with an arrow at approximatley 11 o;clock show on the LCD screen. Timer can then be used. To cancel, Press button and rotate command dial to normal.
Oct 28, 2010 | Nikon D70s Digital Camera
When I take a pic, there is a delay in the time
There could be several problems like: 1)the focus 2)Self timer set to 2sec or 10sec 3)very slow shutter speed set
Make it as a 10 or 20 second delay on the self timer .Your problem here could be that the settings are not right. Go to the menus and reset all to original or default. Then set menus the way you like. You may have a slow memory card, try changing to a faster card, and test it.
Thank you!
May 17, 2010 | Nikon COOLPIX S200 Digital Camera
How do I use self timer. I set in on menu and I
In the REC mode, press [MENU]. On the "REC" tab, select "Self-timer" and then press right. Use up/down to select the timer type and press [SET].
May 13, 2010 | Casio Exilim EX-Z1200 Digital Camera
Want to shoot a timed pictures ie, a pic of myself and my sister together and me setting the camera on a timer and getting into the pic...what do I do? Don't have manual with me. I have a Canon EOS 40D
Did you know there are two firmware updates available for your camera? For a timer picture, here are the instructions: 1Press the <o> button. (
9)
2Select either <j> or <l>.
Look at the LCD panel and turn the
<5> dial to select <j> or <l>.
j:10-sec. self-timer
l:2-sec. self-timerN
3Take the picture.
Focus the subject and press the
shutter button completely.
The picture will be taken after the
self-timer delay elapses.
You can check the self-timer
operation with the self-timer lamp,
beeper, and countdown display (in
seconds) on the LCD panel.
Two seconds before the picture is
taken, the self-timer lamp will stay on
and the beeper will sound faster.
Do not stand in front of the camera when you press the shutter button to
start the self-timer. Doing so will throw off the focus.
Feb 02, 2010 | Cameras
I have a powershot A560 it takes a long time for camera to come back to a place where you can take another picture. I cant find a place on the camera where I can reset the timer.
I use an A550 and an A570, and when the batteries are getting low, they slow down between pics. Also, if the flash is used, IT has to recycle between uses, and THAT takes time. On MY cameras, I press the "function" button, and look for DRIVE mode to change timer settings. Hope this helps.
Oct 22, 2009 | Canon PowerShot A560 Digital Camera
Does the samsung s630 camera have a self timer(to take pictures)?
yes it dose you have to press the right arrow > button and on the left side of the sceen it will have a little pic of a clock kind of thing and you can set it for two pics or 1 in 15 sec or a quick self timer pic that will give you 10 secs but you hae to press the button a cuple of times to get diffent timers setting
hope it helps
Jul 17, 2009 | Samsung Digimax S630 Digital Camera
Timed pic taking
Press left on the multiselector (marked with a one-handed clock). Once the self-timer has been selected, you start it by pressing the shutter release button.
Jun 03, 2009 | Nikon Coolpix L11 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
