Question about Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
New fax constantly says check paper/reload paper
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Posted on Aug 04, 2009
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Our brother intellifax 4100 does not pick up the paper. Is there a protocol to follow and or a repair kit etc??
make sure paper stopper in cassette is not pressed too tightly against the paper. common problem on these models. best to leave an 1/8" gap.
hth,
razors
Dec 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Will not allow printing from the bottom internal tray; it does pr
SOUNDS LIKE YOU MAY HAVE A SENSOR THAT NEEDS TO BE RESEATED LIFT THE FRONT COVER AND LOOK INSIDE WHERE THE SENSOR ARE GOOD LUCK
Dec 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
The printer keeps saying check paper - re load
check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Jul 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 skips
check the paper size settings, that it is set to the same size as the actual paper
~50% chance of being a solution, cant do better
Jun 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Fax Machine 4100 - check or remove original message
Sounds like something is going on with your ADF. It should be looked at by a technician.
Jun 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Mar 03, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
309 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
