Question about Dell 5110cn Laser Printer
003-345 Do you know what the error code 003-345 upon power up is? Thanks for your help.
    Master:
  • 848 Answers
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 5100cn laser printer
Posted on Jul 02, 2008
    President:
  • 1,257 Answers
Please reply with exact error so that we can find solution....................thanks.
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
As soon as my treadmill is powered on I get an error code of dC-6, and it won't function, how can I fix this?
Hallo,
Fisrt of all, i hode like to thank you for you kindness.
I have more details of the machine.
Marc: GREEN MASTER
Model: 928
i Hope that can help you.
Thanks again
Sincerely
Carlos Silva
Feb 14, 2014 | Lifespan Fitness Treadmill Walking Belt...
ERROR CODE 65OO ON MY MP830 HP PRINTER
Canon MP830 "6500" is a PCI bus error code detected upon self check. Parts affected and needs replacement is the Logic Board. You have to replace this parts to back the unit in operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hi my panasonic sa vk90d is giving me an f61 problem when i turn it on
F61 is an error code(protect error code in other brand) for panasonic home theater system. This will trigger if the unit gone to overload to avoid further damaged to other parts. This code is quite technical if your not handy with electronics. However I will say to you the common caused of this error code.
1. Output IC - this is the most common caused of the error code. Once shorts happened to this IC, it will trigger the error code. Exposure to high volume and/or running in the long time will caused this IC to shorts and produce an overload.
2. Shorted Speaker - if one of your speakers shorts, error code will appear also. This may isolate by disconnecting the speaker to the set and play the unit naked. If the symptom still there the fault came from the unit itself.
3. Shorted Inputs - inputs connector is also prone to shorts due to frequent bending and pulling. To isolate this from fault, disconnect all the inputs connected to the unit like the aux input, antenna, mic, etc.
4. Faulty power supply - once gone to out-of-regulation condition, the error code will appear to protect the most expensive parts from further damaged. Bad solder joints in this section is also to consider.
5. Faulty Fan and its circuitry - F61 will appear only after a minute of operation not upon powering on the unit. Check the fan if working or not...
I would advice you to send the unit to your local Panasonic service center and leave the expert isolate the symptoms.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
May 12, 2011 | Audio Players & Recorders
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
I have a HP 6180 all in one printer power error code
Read through NINETEEN(!) other FIXYA "solutions" for the '83C00020' error: http://www.fixya.com/tags/83c00020
Pick the one that works for you.
Jul 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
We have error code E000001-004 upon turning it on, then the screen goes black and no copies can be made.
You have a faulty fuser unit that needs replacing. The fuser unit is the unit that gets VERY HOT in the left drawer section. Two screws either end of it removes it. Check that there is no paper caught inside it causing it to overheat and then, when you put the machine back on you will have to reset the error code in engineers mode. Resetting the code may get you out of trouble for a while. To do this press the following buttons in this order:
the 'head' (a head with a star symbol inside) then hold down the '2' and '8' keys at the same time - then press the 'head' key again quickly - this will get you into service mode - press 'COPIER' then 'FUNCTION' then 'CLEAR' - now press the top selection 'ERR' followed by the 'OK' on the bottom left of the screen. Now turn the machine of by the power switch and wait 10 seconds. Power up now and if you're a lucky one, you'll be back up and running but for how long I don't know. Maybe 5 mins maybe 5 months.
Good Luck
Nov 04, 2009 | Canon imageRUNNER C3220 Color Copier
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
Frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Jun 11, 2008 | Frigidaire Ovens
Dell 5110cn Laser Printer Logo
342 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
