Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes wont turn
Ive checked and cleaned filter several times and the the brushes still wont trun
  • intsolkf Apr 04, 2009
    The brushes worked both times I cleaned the carpets. I turned the brushes off when I cleaned the car seats. When I tried to use the cleaner months later to clean the carpets I turned on the brushes but they would not turn. I have cleaned the filter every time I used the machine.
    President:
  • 1,673 Answers
Remove the brush block, turn the unit on its side and watch the square hole to see if it rotates. If not, then the turbine(#23) isn't working, if it is, then is the shaft on top of the brush block broke off, if it is, replace the brush block.
Posted on Jul 27, 2008
  • 4 Answers
I had the same problem on two different models with the spin brush system,,,and on both it was a steel bearing inside the spin brush motor that had got rusty from mouisture and froze up...bad idea to put steel parts with a plastic setup in a carpet cleaner...I ordered the sealed bearing from Grainger for 5 buck a piece.
Posted on Mar 11, 2009
I,am look for asolution, brush wont turn
Posted on Nov 26, 2008
Its not turning brushes all the time & it has very little to no suction on floor or hand tool modes
HI, it's Jim from Crucial Vacuum!
If your vacuum is experiencing difficulties with suction there are several places you can check to help your vacuum operate at its peak performance. After applying these solutions you should see an improvement in your vacuums suction and the maneuverability of the brush roll.
Lets check out your brush roll first since that's experiencing issues with turning. Look for any noticeable debris, and be sure to manually rotate the brush roll to unearth any hidden clogs that may be behind your brush roll. If you see carpet fibers, or strands of hair remove these with a razor, or scissor.
How do the bristles look on the brush roll? If they're loose, or look worn down then it may be time to replace the brush entirely.
Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. If your brush roll isn't operating properly it won't be able to pick up dirt and debris.
Be sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum.
If you're also getting little to no suction from your vacuums hose and attachments then check your vacuums hose for a clog. Stretch it out as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 01, 2015 | Vacuums
Dc40 not sucking enough dirt
Filters clean? Motor running correctly? Pipe blockage?
Nov 24, 2014 | Vacuums
I have a cannister vacume, Fuller Brush red model # FB-DCC when I turn it on it will shut itself off in about 30 seconds this will happen several times then it will not turn on. I do not have the owners...
First, the word is "VACUUM." Second, it's obvoius that your motor is overheating. When's the last time you CLEANED THE FILTERS, per the operating instructions?
Nov 07, 2010 | Fuller Brush Vacuums
Ive changed the filter and checked the hoses but vacuum doesnt pick up ...when its on the dust is being blown out the bottom of the vacuum....i took the canister off to test the suction its fine...also...
have you check the roller brush and drive belt? It may be your belt has broke or is slipping and therefore not turning the brush.
Turn on machine and power head see if brush is turning if it is put a small amount of pressure on the roller. If it stops turning replace the belt
Nov 18, 2009 | Kenmore Vacuums
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have no suction power but the brush feature will turn on & spin
the same motor that turns the belt is sucking at the same time. your prob is just behinde the brush there is a pickup hole. tahe a wire coat hanger and shove it through unti you see it were the hose plugs in the back off the vac. ming did the same thing and i see these in the trash all the time. I clean the shoots and sell them on craigs list. if it was the reset you would not have any power at all
Jun 13, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
Brushes wont turn on shampooer
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Dec 24, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
"Please clean Roombas brushes"
Same thing happened to me. After "cleaning" the brushes and emptying the filter several times, I realized that the brushes were not properly secured. One of the yellow fasteners needed to be pushed closer to the middle nearer to the brushes. It was not secured properly. When I did this it fixed my problem.
Dec 20, 2008 | Roomba Robotic Floor Bagless Vacuum
Brush bar wont turn, Bissell smells like burning rubber
The belt just goes from the motor shaft to the brush roll. Do the ends of the brush trun freely, or is one of them froze up, if so replace the brush roll. If it is ok, try to turn the brush roll by hand, maybe the belt got pinched and won't move.
Aug 25, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
953 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
