Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak 5500 all in one printer
Printer wont print black. It will only print in color.
Steve Masker
smmasker@yahoo.com
727-501-6478
  • 5 more comments
  • smmasker Jul 01, 2008
    I can not print with black ink.
    I changed the black print cartridge twice and even the new cartridges don't print.
    I have the Kodak 5500 All in one printer. It will not print with the black ink cartridge. I have taken the cartridge out and cleaned and replaced with a new cartridge. It still will only print in color.
    I am not getting any error messages it goes through the printing cycle and I can hear it printing but only the color print is on the paper.
    I have the Kodak 5500 All in one printer. The Black ink cartridge wont print. Fixya experts keep telling me to clean it with window cleaner -I did and I also put a new ink cartridge in and it still doesnt work. Ive only had this printer a few months but have had it release full pages of heavy black ink while printing.
    I have removed the ink cartridge and used windex on a paper towell and kept dabbing the spot where the ink cartridge touches the little platform inside the tray that holds the ink cartridge/ Is that correct?
    So far have not had a solution that has worked.
    This Kodak printer is used daily and has never went dry. It is only a few months old. I have always had problems with it unloading a half page of black ink sometimes while printing.
    President:
  • 2,712 Answers
First, make sure that you are using original Kodak cartridges and not refilled or generic ones. Also make sure that you have inserted the cartridge correctly, and removed any backing plastic covers, etc.
Secondly, try the nozzle check, and manually clean the print head with moist paper towel.
Should neither work, try a hard reset: Unplug the printer from PC and power source, wait about 5 minutes and replug everything and try.
If even that fails, it means you will have to call in the manufacturer, as its likely to be a circuitry issue, or some other problem..
Posted on Jul 01, 2008
    Sergeant:
  • 243 Answers
Your best bet then is to send it in to the manufacturer as it is still under warranty.
Thanks,
Lee
  • 6,487 Answers
Performed a nozzle check, and the black grid (at the top) as well as solid
You definately have a clog. A friend has the same trouble. They
happened to let the ink run completely dry is what caused the problem.
Did you use generic inks or let the printer sit idle for a long long
time?
Hope that help a bit.........
  • Mark Gil
    Mark Gil Jul 01, 2008
    If that's the case better have that replace...
    Genius:
  • 1,011 Answers
Sir,
Reset the printer, installed updated firmware and home center. Mbp. Called support. On hold for 40 minutes.
Thanks
Good luck
Don't forget to rate the solution
    Master:
  • 638 Answers
Its because ur black ink head is clogged.remove the ink head n leave the bottom of the head dipped in a little bit of water.it will dissolve clogged ink.reinstall ur head into the printer n then clean ur head with the head cleaning option to maintain the flow of ink.it will work properly after that 4 sure.keep me updated.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • Kodak Master
  • 691 Answers
Have a look at my previous posts about intensive cleaning. This works in many cases with ink jets that have suffered a clog in the print head.
View it HERE: http://www.fixya.com/support/t138226-printer_not_printing
    Genius:
  • 1,665 Answers
Run print head cleaning procedure and try again
    Genius:
  • 2,035 Answers
Are you able to make black and white copy if yes then you need to go the control panel select printer folder and right click on the printer icon you tab printing preferences once you need to search for the check box print all documents in black and white,
If the copy is not working you need to clean the contacts of the black cartridge .Take a warm, damp paper towel or napkin and gently clean the bottom of the car where ink comes repeat the same process with dry paper towel and try to print , if this did not work you need to replace the cartridges as the ink may be dried.........
  • Anand Kumar
    Anand Kumar Jul 01, 2008
    Are you getting any error message in your computer.........
  • Anand Kumar
    Anand Kumar Jul 02, 2008
    Are these refilled or compatible cartridges?
    Please print a calibration page on your printer and lat me what colors do you see ?
    http://www.kodak.com/eknec/PageQuerier.j...
    And download the manual and follow the instruction to inset the cartridge and to print a calibration page..........
  • Kodak Master
  • 1,879 Answers
Greetings,
Perform print head cleaning using the driver.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • 1 more comment
  • monk3ybidzness
    monk3ybidzness Jul 01, 2008
    tutorials and other information can be found here
  • monk3ybidzness
    if you don't get any improvement after the head cleaning, replace the ink cartridge
  • monk3ybidzness
    Check warranty then - common issue for inkjet printers : the printhead gets clogged.
Printer wont print black, it only prints in color, also the printing fades
printing in black
* change the properties of your printer --->> Printer icon-->>Properties-->> select color or black and white grayscale.
fading print
*clean the cartridge printhead through the computer or manually (remove cartridge and wipe with cotton cloth with water). Also, clean the scanner window (glass).
http://printerquickfix.blogspot.com/
Jul 19, 2011 | HP DeskJet 842c InkJet Printer
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Not printing
Here are the best instructions on how to clean the print cartridges.
Feb 25, 2009 | Lexmark X5150 All-In-One InkJet Printer
My HP printer stopped printing in color
sure...it is most likely a print settings issue on your word application, maybe. Check that print settings to ensure it's looking for color and not greyscale
Dec 12, 2008 | HP Office Equipment & Supplies
Balck ink not working
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
The printing head have some dryed black ink inside.
Look at Canon i550 section in this website. I have posted several answers on how to clean the print head.
Feb 09, 2008 | Canon BubbleJet i560 InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
