Question about Casio PRG-40T-7 Pathfinder
Chabging the batterys on the prg 40
Got the back cover all the screws in a safe place but how do I get the batterys out from underneath the metal plate. The manual says nothing.
If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
Posted on Aug 04, 2008
  • Edward Willhoft Dec 23, 2013
    Double cell holes on perimeter side while those on other cells towards centre of watch.
How to prevent water leaking inside,after replacing the batteries.. should i replace the gasket to? after replacing the batteries....
Normally gasket has not to be replaced after battery change.But all depends of the use.For example if you wear the watch in salt or pool water and never flash it with fresh, clean water after,it may be a cause of gasket wear.Remove the back cover.Replace all 4 batteries(be sure first that you can do this with extreme caution as all parts are tiny).Remove gasket.Check gasket condition(cracks,gasket too dry and hard).If gasket OK, apply a small amount of special silicon compound for watch gaskets,all around and to all sides of the gasket,put it back in place,carefully.Be sure that gasket is set correctly all around.Put the back cover in place and screw with much caution (not too tight-a little resistance).Your watch now normally is water resistant.But if you want to be 100% sure,take the watch to a serious repair center where it will be tested under pressure ( 3 Atm average).Then they will tell you if your watch is 100% water resistant.
Oct 11, 2010 | Casio PRG-40T-7 Pathfinder
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    Hi, I have a casio protrek PRG-80T-7V(triple sensor). I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch....
    Try to reset the watch.But first be sure that you capable of doing this.
    Reseting the watch procedure:
    1)Remove the back cover.Be sure that you have the appropriate screwdriver.Keep the 4 screws safe, not to loose them.
    2)On the chassis of the watch (metallic surface) somewhere there is a hole with AC (All Clear) written nearby.
    3)Use one little thin retracted paper clip (not totally retracted).Insert the retracted end of the clip into the hole, gently, until it touches the end and with the upper part of the clip contact the chassis (metallic surface). Wait for 1-2 sec and remove the clip gently.The watch is now reset.All functions have been set to factory settings.
    4)Put back in place and with caution the back cover, respecting right (up-down) positioning and taking care that the O-ring gasket is well in place,first.
    5)Holding in place with one finger the back cover,screw back screws gently and without applying excessive force (delicate job) until you meet resistance, in the following order:
    Up-right,down-left,up-left,down-right.
    After setting the time/day/date etc try to calibrate compass both ways as you did before.
    I hope this will solve your problem.
    NOTE:Again,be absolutely sure that you are capable of doing this.
    It is a bit delicate job.If not,you better bring the watch to an official CASIO service center.
    Apr 27, 2017 | Casio Protrek Triple Sensor PRG70 1BVDR...
    How do I reset my Casio PRG-40 following battery replacement?
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
    Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
    How do you unlatch the battery of a timex ironman watch. I have the back open now
    You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
    Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
    Battery replacement
    You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
    Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
    Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
    Good luck.
    Do not forget to rate, please.
    Mar 11, 2009 | Casio PRG-40T-7 Pathfinder
    Changed dead batteries on PAG-40. Still one dead watch
    There is a very small sticker with very small red print just adjacent to the battery compartment. This little sticker states "once batteries are replaced, you need to touch AC with tweezers". I did it with metal tweezers and the watch display came to life. Good luck!
    Jan 15, 2009 | Casio PRG-40T-7 Pathfinder
    How to change battery in Casio wave ceptor4305
    If there is no any screws holding that 'metal strap' then carefully check both ends of it. You will notice that the ends (or one end) are snaped over the little plastic hooks. Take pointed tweezers and push that end outwards (away from battery) and the contact (metal strap) will pop out.
    After battery replacement, just push the contact back into place till it fixes.
    If there are screws holding the contact, just undo them.
    Be quick when replacing battery- you have 2 or 3 minutes to do that, otherwise all data will be lost and you will need to reset watch completely.
    Dec 19, 2008 | Casio PRG-40T-7 Pathfinder
    Casio SPF 40 beeper not working after battery change
    There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
    regards,
    Pieter
    Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
    Battery replacement prg 40 model 2271
    The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
    Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
    Casio PRG-40T-7 Pathfinder Logo
    370 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
