Question about Packard Bell Computers & Internet
Installing a 2nd 256m ram memory card into packard bell imedia3501
  • Packard Bell Master
  • 13,433 Answers
Installing more memory to a pc is very universal and is done the same way into all computers out there.
First unplug your pc
Open the side cover or remove the cover debending on your pc case.
Turn the pc sideways on the floor or table
and locate the memory slots near the cpu.
In this pc we have 3 memory modules installed
In this case I would have to remove one of the original memory modules first before installing a new one.
But in your computer you should have a extra slot open.
Simply insert the memory into the slot and turn the white switches on the sides to lock the memory in.
And you are done.
Posted on Jul 01, 2008
Packard bell easynote M5284 - black screen after installing new RAM
Sounds like the memory is incompatible with the laptop. Remove the memory and install orginal memory and boot again to see if every works correctly.. If so then either a memory module is bad or motherboard wont support the new memory (size or type)
Mar 14, 2013 | Packard Bell EASYNOTE M5284 COMPATIBLE...
Packard bell easynote mit gha20 M5284 - memory upgrade
Hello Wallace.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=9B9F5310A5CA7304
Try this, i think that`s it.
mfg Gue.
P.S.: Do you know Gooooogle ?
Feb 28, 2013 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Hi Guys I have a packard bell istart 1359, memory max is 2048mb and I currently have 512mb installed. I purchased 2 x 1gb ddr2 pc2-5300 -cl=5 -unbuffered -non ecc ddr2 - 667-1.8v -128 meg from crutial. I...
some systems require ECC it may be as simple as obtaining ECC Ram......u can try checking the memory that cam with it to see whether it is buffered and ECC if it is you will have to obtain same type of RAM
Apr 15, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
I want to share memory with my graphic card
the system cannot share memory with your graphic card, the hard disk can share its free space with the RAM to increase performance when you have little RAM installed.
I recommend buying a graphic card with 512mb memory for your system.
Jan 09, 2009 | Computers & Internet
How do I instal two 1gb ram cards into packard bell 1508/2 pc
You need to take the pc apart.
open the case.
then you need to find the memory slots
Remove old modules or place new ones in if there is room.
Jun 27, 2008 | Packard Bell Computers & Internet
Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Mar 08, 2008 | Computers & Internet
RAM extension modules for a Packard Bell Internet Dream Machine 5805i
try going to crucial.com website, they can scan your system and tell you the ram replacements or you can search for it.
Jan 22, 2008 | Packard Bell (146537-01) (14653701)...
Packard bell easynote m5262
This is hard you have to take the laptop apart to get to the ram. but you have to remove the screen to get to the case screws.
Dec 08, 2007 | Computers & Internet
Computers & Internet Logo
91 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
