Question about Cameras
Computer is not reading camera
I am getting this message..The computer cannot detect the scanner or camera.Please make sure the device is truned on and is properly connected to the computer.
  • 983 Answers
I think you have not installed the drivers given by the manufacture .. try installing it ....
if the problem persists then check the cable is connected properly or not ...
if it is connected properly still not working then there may be some problem in the cable change the cable & try again ...
if you still persist the same problem then there may be some problem in the port in pc ...
or the driver database might have got corrupted just try reinstalling the operating system ....
this solves your problem
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate the solution
Posted on Jul 01, 2008
> My computer does not detect my scanner >
Search on-line see if you can get an-updated driver for it. Some windows updates remove old drivers.
Apr 09, 2017 | Canon CanoScan N640P ex Flatbed Scanner
When "plugging in" the EasyShare 875 camera into my computer, I keep receiving an error message stating "Computer cannot detect the scanner or camera. Please make sure the device is turned on and...
Seems like your trying to use the camera from a shortcut? Instead, connect the camera and turn it on, if the screen of the camera has a selections creen, select PC or similar.
Then open my computer or computer from either desktop or from start menu.
In my computer you should see the camera or a removeable storage device, inside you will find all the pictures of the camera.
please let me know if you need further assistance.
Oct 12, 2010 | Kodak EasyShare C875 Digital Camera
The computer cannot detect the scanner or camera.Please make sure your device is on and make sure it is properly connected.
You must install the driver software for the scanner /camera before you connect the scanner /camera to the PC.
Since your model /make is not specified , I adivce that you seach for free downloads of the software for the make/model from the site of the manufacturer.
Sep 17, 2010 | Office Equipment & Supplies
Film & slide converter will not copy fotos.
Verify that you have good connections at both ends of USB cable. Verify that you have the camera powered on. Verify that you have media card or whatever in the camera that you are trying to read. If that doesn't work typically there should be a trouble shooting section in the manual. Windows should be detecting the unit. After it's connected look in "my computer" and see if you see the device / detachable storage listed among available drives and try navigating manually to your media.
Oct 23, 2009 | Office Equipment & Supplies
C170 trouble downloading
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 28, 2009 | Olympus Camedia D-425 / C-170 Digital...
Scanner on my "All in One HP 6110" refuses to work any longer
Please get back to me with the following information to assist you further.
  1. How is your printer connected to computer? (USB or Network)
  2. Have you installed Full feature software?
  3. If you are connected with USB cable make sure the cable is connected directly to the printer without any USB hubs.
  4. What is the OS?
  5. Are you able to copy a document on the printer (stand alone copy)?
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Getting an Error Message when trying to scan
SCSI devices are detected as the computer is booting. If your scanner was powered on after your computer was already up and running, it may not have been identified by the SCSI card. Try leavinging the scanner connected and powered on and then reboot your computer. Also, the pins on the SCSI cable connectors are easy to bend; inspect the rows of small pins with a flashlight or just try a different cable if you have one.
Dec 01, 2008 | Office Equipment & Supplies
No pictures found on pc
Easiest way is to put the media card into a USB card reader attached to the computer.
Apr 19, 2017 | Canon PowerShot A95 Digital Camera
Picture problem
is your computer connected to scanner?? if so remove the scanner and deactivate the scanner software in computer then the problem will not come.
Nov 18, 2007 | Canon PowerShot A95 Digital Camera
Cameras Logo
181 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
