Question about Brother IntelliFax-2820 Laser Fax
Message that reads Check paper/reload paper
We have a new fax that continues to have a message that says check paper/reload paper, our old fax did the same thing. There is paper in the tray. We are having to open the front and take out the paper tray and close it in order for the fax to work.
I need the drivers
Posted on Jul 09, 2008
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
My read out says check paper size, when i reload tray all it does is print out an old fax. I have letter in there and have gone though the trouble shooting in the manual.
Did you try clearing your remaining jobs? Fax, menu, arrow down to #2 (fax), menu, arrow down to #6 (remaing jobs)....
this helped me.
jb
Apr 27, 2010 | Brother MFC-9420CN All-In-One Laser...
Brother MFC 8220 has a red ligth with an error message saying check paper reload paper. I put the tray correctly with papers loaded and it keeps. Cannot print, copy or fax anything
mine was doing the same thing. pull the paper tray out and there is a black lever next to the feed drum, it wouldn't move up and down. I took of the cover and slid the lever over to the left so it would move freely and now it is fine.
Mar 12, 2010 | Brother MFC-8220 Fax
Lately, our fax has not been working and the message 'Check/remove original and press stop key' will appear on the LCD screen. Even after removing the original or clearing any paper, the LCD screen...
Thre is a "finger" sensor on the input tray. It is stuck in the "down" position. The fax machine falsly senses paper on the sensor.
Use compressed air (from a can) to clean the sensor and "work" it to free it. Do not lubricate it (no WD40 or duct tape, please)...
Sep 28, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
MFC -9420 CN Printer/Fax Scanner
I've seen this before...
The machine is calling for legal sized paper and it thinks it has it in the paper tray. Check the back stop that is inside the paper tray. It should be a green guide that is closest to you if you pull the tray out. You may have to lift up a flap on the end. Make sure that the paper stop is on the correct paper size for what is in the tray. Hope this helps. Let me know if you need any more assistance.
If this helps you please rate it as Fixya!
Nov 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFax-2820 Laser Fax Logo
365 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
