Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Easy off turned my gray powder coat on my harley black.how do i remove it from the powder coat?
Totally agree, ez off is a extremely strong lye. damage is done! however, you can remove it with some high quality air craft paint remover but look out for other parts. the next suggestion is if the powder is in tact but discolored, clean it very well and go but a can of krylon fusion paint made for plastic in a shade that suites you. tape off the bike and spray the powder. this paint will really stick and holds up well. i used some to make a colored wiring harness as i could not get colors i needed in the wire. if you remove the powder, you will have very ugly aluminum staring back at you. if you go that route, buy a dremel tool and polish the aluminum and coat it with some diamond clear from eastwoodco.
Posted on Aug 27, 2008
There is no going back, you have chemically changed the powder coat composition. Learn your lesson well and next time use a H-D listed cleaner and a very soft brush.
Posted on Aug 26, 2008
What is specified front fork oil capacity for a 2014 street glide
2014 Service Manual says "Pour slightly more than 24 oz. (710 cc) Type 'E' HYDRAULIC FORK OIL directly into the fork tube." so you are going to need at least 48 oz for both.
Jul 17, 2014 | 2011 Harley Davidson FLHX Street Glide
Tip
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
I want to strip down my 2001 road king & put it all together on a paughco swing arm frame
Hi Anonymous, the first thing I would do is purchase a service manual and two cycle lifts from the websites below they run about $100 a piece including shipping, the manual $6.50. Have your new frame powder coated to the color you want. Then remove the fenders and tank, transfer the front end and rear wheel assembly and shocks, so you have a rolling chassis on the new frame, then the engine and trans and the rest as you feel comfortable with. Take your time, be patient, pay attention to detail, torque everything to book specs. and read your service manual before you do any procedure. When you finish you can sell the extra cycle lift to a friend enjoy your new creation:
Harley Davidson Manuals Mark Workshop
Black Widow Motorcycle Jack Lift
Good luck
Feb 18, 2014 | 2001 Harley Davidson FLHR - FLHRCI Road...
Exhaust system gaskets
Hi Anonymous, look for gray powder or black soot residue at cylinder head and exhaust system connections. Good luck
Nov 02, 2013 | 2008 Harley Davidson FLHRC Road King...
Remove rust
tear down the machine remove all parts and clean all grease take five mixer parts to powder coat shop and have sand blasted and re-powder coated and then re-assemble. cost about 80 busks and 20 more for new gease and gasket.
Aug 07, 2013 | KitchenAid Food Mixers
How is powder coating applied?
Electrostatic spraying is the most widely accepted powder application method by powder coating services and the electrostatic powder gun is the most important piece of equipment in this method. A fluid bed is also used for applying powder coating.
Jul 12, 2013 | Washing Machines
I made some yummy waffles in my kitchen waffle maker and forgot about the one waffle. Several months later, I went to make waffles again and found a terrible black powder in the appliance. The waffle had...
Unfortunately you have ruined a perfectly good waffle maker...
The coating in there is a teflon coating that needs to be applied properly for it to work...if you try to use it in the condition it is in then the waffle will stick to the plate...
Best thing to do is to trash the old one and then buy a new one...
heatman101
Jun 24, 2011 | KitchenAid Kitchen Appliances - Others
I have ball bearings in tool box want to powder coat it will heat effect bearigs if i run it through 400 degree oven
It shouldn't harm the metal bearings but it will burn off the grease which could affect you powder coat adhesion and sometimes those slides have plastic parts in them too which could melt -ruining the slides, can you remove the slides and then reinstall them sfter the powder coat?
Jun 14, 2010 | Hand Tools
Rubber coating on my tasco exp scope has become sticky and seems to smear black when rubbed. any suggestions?
Dust with fine Talcum powder, ie baby powder. Distrubute powder over rubber and it will harden up the rubber, let sit and gently rub in. After a couple of minutes dust off excess. repeat if required.
Sep 13, 2009 | Tasco EXP-1042 (10x42mm) WP
Griddle needs to be cleaned
Slide an old towel underneath the griddle to protect any painted surfaces.
Then carefully spray easy off onto the surfaces, or, soak another towel in easy off or other cleaner, and lay on the soiled surfaces, pressing down to assure good contact. Lay another towel on top, and allow to lay there for awhile.
I really dont' think you've got anything to worry about. Most cooktops are today are powder coated, rather than laqeur painted. Powder coat is a hard, baked on surface. It won't solvent melt like finsihes of old.
Jan 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
