I have a 24 volt power supply for a piece of industrial machinery that isn't working. I opened it up, applied 120 vac, and began probing different components with my voltmeter. I came to a 100 ohm 1 watt resistor that appears to be connected to an SCR, and put my meter probe on it. The power supply made a funny noise and began working! I can repeat this everytime I power down and back up, and it works even if the probe is unplugged from the meter. probing the resistor with, say a piece of wood will not work. I have replaced the resistor and there is not a bad connection. Any ideas?
  • 550 Answers
The meter is not infinitely resistive -effectless, it has effect on the circuit, and may be enough to switch the scr on.
np-pn junctions in scr fail occasionally, the voltage fluctuation due to the meter may have been just enough to trick the rectifier, the scr may need to be replaced,
Has there been any major power suge, lightning strike 'close (in lightning terms) to the unit', output short, to the power supply, slilcon can really only be tested out of circuit its often easier to replace than test
Posted on Jul 01, 2008
Is there a specific tool recommended to loosen the set screw so I can change the tip? It doesn't mention anything in the directions
Engraver Kit / Model: 290-01 - Dremel.com
www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=290-01
DremelFeaturing a replaceable carbide point, Dremel's engraver kit lets you work on metal, ... http://mdm.boschwebservices.com/files/Dremel Engraving Tool 290 ...
Amazon.com: Dremel 290-05 120-Volt Industrial Engraver ...
www.amazon.com/Dremel-290...Engraver/.../B000VZ...
Amazon.com, Inc.
Rating: 4.2 - ‎62 reviews
Dremel 689-01 11-Piece Rotary Tool Carving and Engraving Kit .... tips and came from a different source ie there is no Dremel 290-05 tool. ... On the very first tool, afterengraving the serial number, the diamond tip began to loosen and slip out. ... When I returned to the engraver to tighten the set screw the tool fit perfectly, ...
Home Depot Dremel 120-Volt Corded Electric Engraver ...
reviews.homedepot.com/.../dremel-120...engraver...tool.../questions.htm
Afterwards you can remove the paper and glue with a simple adhesive remover or alcohol. ... I use the Dremel Electric Engraver Tool to engrave manufacturers name and model .... hardware store and they should be able to supply a new set screw for you. .... The 290-01 Engraver is for engraving applications only and is not ...
FAQ - Customer Service - Dremel
www.dremeleurope.com > Home > Customer Service
Dremel Europe
Dec 16, 2015 | Dremel 290 - 01 Engraver
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
My mixer wont power up. the only light that comes on is red led +48 v
This MAY be a power supply problem. We need to find if the power supply is putting out what it is supposed to. Using a meter, put one probe in pin 1 (ground) of one of the mic connectors, say channel1. Put the other probe in either pin 2 or 3 of another mic connector... Note we are using different connectors as there often isn't enough clearance for the probes in the same one... With Phantom power turned on and LED +48 lit, how much voltage do you read? If it is say 40 volts or more, then power supply is operating.
If the supply is operating then a POSSIBLE problem is a connector has fallen off where it connects to the supply or the main board.
The power supply provides several voltages such as 5 volts, 12 volts and 15 volts of various polarity.
If the 48 volt supply is found to be operating with the above test, then since the switcher and transformer are shared, it is likely the other voltages are available.
CAREFULLY open the unit and look for a loose cable.
PLEASE NOTE: This is a switching type power supply and part of the supply runs at power line potential. Only work on the supply if you are skilled and have an isolation transformer for your own safety.
Sep 21, 2010 | Behringer XENYX 2442FX Mixer
Can I use this timer, using only 120 vac to supply a 120 to 12 vac transformer?
no this timer is rated for 240 volts so therfore the clock motor is 240 volts. You will need to purchase a 120 volt clock Good luck!
Sep 11, 2010 | Intermatic Electric Water Heater Timer...
Pump Cycles on and off. Runs for 10 to 15 seconds then shuts off for a period and repeats the cycle.
Is this motor thermally protected? Are you running it on 240 VAC and the pump is set up for 240 VAC? (120 VAC- and 120 VAC?). Pump is on its own circuit, or one adequate to supply the proper volts, amps and watts? No extension cords involved?????????
The motor does this because it is over heating for some reason ... improper voltage comes to mind.
You say it starts but will not run ... a faulty run winding comes to mind (start circuit is evidently ok)
Overheating can als be caused by an obstruction in the suction or discharge ...
May 31, 2010 | Polaris Pb4 - 60 Booster Pump
No power, no lights on laptop
I think you should check the real power supply ... 120 V in and what comes out ... volts (ac - dc) and amps or what fraction of an amp.
Please compare the old with the new power supply. The new power supply should be the same volts - same kind (AC or DC) and at least the same amp rating. You can use higher amp rating but not lower - lower will burn up - literally)
Volt meter ... always set it above the suspected voltage. Batteries are always DC. Houses, buildings, etc always AC. Power supplies - could be mixed - ac in and dc out.
So if you were measuring in your home, you set the meter to 130 or higher on the AC scale. If you were doing your auto, 24 volts DC (or so).
House current, probe color doesnt make any difference. Should read about 120 Volts between the narrower (or right side/ground down orientation) or the two slots and the wider of the two shots (wide should be the neutral side - ground on the bottom). You can prove the hot side by measuring to the ground. White wire to ground = no reading. Black wire to ground = 120 volts. (The black and white are INSIDE the electric outlet. You can use either probe to do the measurement.
I hope this helps you.
If you have more question, please let me know.
Thanks for using fixya.com
a
Oct 23, 2009 | E-Machines M5309 Notebook
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
