I have connected the S video wire to my television but not able to see the output. Do i need to do something else apart from just connecting the S Video wire?
Enable the s-video port in display settings after connecting cable
screen resolution setting is important, NOT setting it before enabling s-video can damage tv & pc
IBM instruction page http://www-307.ibm.com/pc/support/site.wss/MIGR-58625.html
No place to put your RGB on the PC or on the TV? Your TV should have an RGB port for sure. The "green" may be yellow instead. Your PC will need a video card installed that features a RGB output to make it work from there. Some PCs use DVI out instead. You would then need a DVI/HDMI converter to plug into your TV's HDMI port and then to the PC.
It may have something to do with the settings under audio output devices. See if you have options, and ensure that the headphone jack (I assume that's what you're using) is set as the default sound device.
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
The LG 32LD550 television has HDMI and VGA. Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter. So all you need is either: 1) mini-DVI to VGA adapter. 2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
The PSP system (model PSP-2001 and PSP-3001) includes a video-out port which allows users toconnect and play the PSP system on an external display or television with AV inputs. It is important to note -- you can
Component AV Cables (model SCPH-98550) The Component AV Cables connectto the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal to a television display. The AV Cables support photos, videos (including UMD movies), music, and games. Please note for games to output onto an external display, the display must support progressive scan.
Composite AV Cables (model SCPH-98548) The AV Cables connectto the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal toa television display. The AV Cables support photos, videos (includingUMD movies), and music. However, output of games are only supported by PSP-3001.
The laptop has a blue 15 pin D-sub video port, connect a video cable from this port to the 15 pin D-sub on the HDTV.
Power up the TV first and then power up the laptop, the video signal will automatically switch to the external video output.
You can toggle between the LCD and TV or both on together by pressing the blue Fn key + the F7 function key several times.
You need to set the TV to input from the source that the computer is connected to.
You also need to make sure the computer is set to output a signal to it's S-video or video out port (usually Fn F5 or something like that, or there may be an software switch in your desk tray where it is to be tripped.)
The hdmi output and inputs are on a modular circuit board that you only need a philips screwdriver to swap out. I need this board as well since I also have a damaged hdmi output jack but have not been able to locate the replacement board. If anyone knows where to look I would appreciate knowing.
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
