Question about Roper Refrigerators
Just opened my freezer on Roper fridge model RT2TDKXKQ, got out some ice cream and it was loose/melting. Then opened the fridge section; light was on turn cold control all the way high then to off and back to middle. Closed the door and did not hear compressor come on, which it usual does under the circumstances. Where is the re-set for this fridge? I would like to try that before cleaning the bottom coils and calling in a repair person. Do you think a re-set might help? Got any other ideas?
Hi there.
It's possible the thermostat contacts have stuck.
You should hear a click when turning from max to 0.
Sometimes a light tap on the knob frees it off without dissasembly. Turn to 0 before doing this with a shoe (hard rubber 8oz mallet)
If the thermostat is broken, you can find a replacement HERE, or shop around for the part number.
Thanks for using Fixya. If this solves your problem, please rate as such. Thanks.
Posted on Jul 02, 2008
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
The freezer has been melting ice-cream
The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
May 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer only works on bottom
The evaporator has most likely built up with ice on it. this usually makes the fresh food section go out first. the best coarse of action is to remove freezer panel and make sure return air or vents are not blocked with ice..if these vents are blocked no ff section locate the vents that allow air to flow down and open...good luck..bruce denton
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Not as cold as it should be
see if there is ice on the back wall of freezer if so this is an automatic defrost problem timer heater or limit switch
Apr 17, 2009 | Whirlpool ED5SHAXM Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
44 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Randall W
Randall W
Level 1 Expert
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
