Question about Maytag Refrigerators
Coils in freezer icing up & will not defrost itself
  • 828 Answers
Locate the defrost timer, should be in the refrigerator compartment in the area near the temperature controls. May see a round hole in the plastic cover which gives access to a clutch head screw, turn the screw clockwise SLOWLY until you hear one audible click. The compressor will shut off and the defrost heaters in the coil area should turn on. If after 25 minutes the unit does not restart cooling turn the screw again to the second click. The compressor will then start cooling.(Replace Timer)
If the system does NOT defrost after turning the timer to the first click and the system restarts after 18-22 minutes your problem is in the defrost heater circuit. Could be an open defrost heater or defrost thermostat. The back wall of the freezer section must be removed to read out the heater with an Ohm meter for continuity.
Posted on Jul 01, 2008
Coils ice up
My best guess is that the drain has some debris in it and the defrosted water from the coil is being picked up and being re-frozen against the coil and freezing up the drain pan. The defrost timer may have failed, the defrost termination button fastened to the coil may have failed, the defrost heater on the coil itself may have separated from the coil or just outright failed. Hope this helps and good luck.
Sep 22, 2014 | True 49 cu. ft. / 1388 liter Commercial...
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Defrost tube doesn't drain water and ice form under crisper trays This is a bottom freezer - drain tube is clean and I need to melt the ice every two weeks
This sounds like a problem with the self-defrost feature of the fridge. The three major components of most self defrosting freezers are: 1) defrost heater coil, 2) defrost terminator 3) defrost timer. The defrost's electric heater coil & terminator (a simple thermal sensor / switch) are in the freezer compartment in *very* close proximity to the freezer coil for the refrigerant (all of these components are usually hidden behind a protective panel) or in direct contact with the freezer coil (as is the case for the defrost terminator) The defrost timer assembly consists of a small clock motor and relay contact points. This assembly can be located anywhere the manufacturer desires.
If the timer motor has failed, or if the contact points in the assembly have shorted or failed in one position or the other - the defrost cycle will be stuck in one position (either cooling or defrosting) or the other. If the heater coil has failed, the rest of the defrost system is probably working ok, but the heater coil will fail to warm up to melt ice build up. The defrost terminator simply tells the the defroster that the cooling coil has reached a temperature high enough to have allowed the ice to melt off of it and drip into the pan & tube. If it has failed it could be telling the defrost system there is no ice built up.
The parts for this job aren't very expensive, and you can fix it yourself *IF* you have some know how, a bit of an electrical background (know how to use a meter and understand electricity) and can disassemble / reassemble the freezer area without damaging the refrigerant lines. You could buy all the parts and replace each, one by one until it starts working again, but that would be a bit expensive. A repairman coming out to do the repair might be even more though. You'll need to get schematics or the service manual for the particular Sub Zero model (probably the serial number, too) to determine the exact locations of the components and follow any troubleshooting steps if provided.
Don't choose this repair as your first appliance repair job though - it is more involved and dangerous than most others due to frostbite hazards of the refrigerant (if allowed to escape) and electric shock.
May 20, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice cubes shrinking and crystalizing in freezer
what is heppening is the defrost circuit and compressor or trying to run at the same time! its either the timer itself or the limit switches inside the wall near the defrost heater coil are shorted closed
Jan 17, 2010 | Freezers
Freezer is not cooling properly. The controls are turned all the way to the coldest setting and the freezer is only about 25 degrees.
it sound like you need to access the evaporator unit in the freezer and see if its iced up and the defrost is working,this can be done by taking cover plate off in freezer section,if its iced up defrost it,clean condenser coils under refrigerator of dust,then turn unit on and see if it cools right again,also if it works for a while then does it again the defrost timer that power the heating coil below the evaporator coil may be bad or the element itself may be bad that defrosts the coil
Jan 16, 2010 | Refrigerators
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
I have a Kenmore side-by-side frig which I was told was mfg by Whirpool: Model 106.51264104 Mfg April 2003 It stopped cooling on both sides. A repr tech replaced "RELAY CAPASITOR ASSY." I now get freezer...
Okay if not the coils inside the freezer section behind the panel that covers the coils is where the ice is located? I don't know of any other coils inside the freezer? Did you confirm that compressor itself is running? Not just the fan and clarify again the location of the ice.If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will inturn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.After defrosting the coils with a hair dryer, they have not frozen up again in several days. I did notice that the air diffuser in the refrigerator side does not seem to open by itself. It is not broken physically. If I open the luevers manually, eventually they will close and not reopen.
OR
Relays will burn out for the same reason a light buld burns out. So many hours of life and they go. Also a power surge from a storm can cause them to go.
If the compressor is cold try a relay. If you hear the compressor click on and then click off after 3-5 seconds try a relay.
Thank You
Jun 01, 2009 | Refrigerators
Refrigerators Logo
125 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
