Question about Lexmark C524 Laser Printer
Color marks on both edges of the paper
Jobs printed from the Lex C524 have color spots on both edges of the page. Kinda look like tire marks! Is there something I can clean to get ride of these marks?
I had the exact problem. It was caused by a defective photoconductor.
Depending on what colour the spots/marks are, the photoconductor for that toner cartridge needs to be changed.
Posted on Aug 21, 2008
Folded prints when duplexing
i would check the duplex pathway for any debris that is stuck there
Jun 11, 2014 | HP LASERJET ENTERPRISE 500 COLOR M551DN
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
How do you get the Lexmark pro 715 Printer to print on Both sides the manual is not very clear
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Go to the:Layout tab > Print on Both Sides (Duplex) area > Print on both sides
- Click Long edge for print jobs with pages that are bound along the long edge of the page.
- Click Short edge for print jobs with pages that are bound along the short edge of the page.
4 Click the Paper/Finishing tab, and then select a supported paper type.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
Oct 22, 2012 | Lexmark Pro 715 All-in-One Printer
No color ink
To solve this issue what u can try is remove the ink cartridges from the printer. Unplugg and replugg the power cable. Clean the copper contacts of the carts using a dry paper towell. Snap the cart back to the printer and install the cart as the new cart. Print the alignment page. Also uninstall and reinstall the driver using the original CD, sometimes Windows can change to an "updated" driver with Windows update. It may have installed a B&W driver.
If all this fails it might be the issue with the encoder strip. Call Lex Tech Support and get help to fix the encoder strip.
Mar 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
The paper has a black mark on the left edge like a roller has ink on it 2in long 4 places
Here are some instructions that you can follow to try to identify and resolve the problem with the black marks.
First click on the following link http://bit.ly/aNzNsl and follow the steps on how to print the Print Quality Pages. Once you have those pages printed Then it will be easy to identify where the problem is coming from. If the problem is more visible in one color than in the others then you might be looking at a problem with either the Photoconductor or the Developer Roller. If the black marks are showing on all the page regardless of color then the problem could be contamination either on the Transfer Belt or in the Photoconductor Units and maybe need to be replaced and/or clean. To clean a contaminated printer you will need to vacuum the inside so that residual toner will not get blown into some other parts of the printer.
Hope it helps.
Jan 28, 2010 | Lexmark C524 Laser Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Spots when printing
It sounds to me like you may have 2 low or defective toners, the Cyan and the Magenta. If you have another machine like this available to you try swapping these 2 toners out to test the theory or you can take these 2 toners out and spin the drum manually (by only touching the gear) checking to see if the spots you see on the pages correspond on the applicator roll of the toners...
May 09, 2008 | Lexmark C524 Laser Printer
Lines along edge of paper
1 of 3 things I can think of off top of my head.
Since they are straight, I would suspect the transfer unit.
If it were just one color it would be that imaging unit.
Unlikely the fuser.
It doesn't sound line an issue called bar coding ,where the machine prints random lines. That would be a software issue.
Take the transfer unit out and inspect it for the marks.
I am assuming the streaks are on all colors correct?
If it isn't on the transfer belt, and on all colors check the fuser and see if its latched.
Jan 16, 2008 | Xerox Phaser 7400DN Laser Printer
Lex-Z25 Blank Pages
need to install my Lexmark Z25 to my laptop.recently upgraded to windows XP
Jan 05, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Lexmark C524 Laser Printer Logo
314 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
