Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire infinity The timer does not work, the only way to stop is to open the door and there is no heat.
  • whdaugherty Aug 02, 2008
    just want to confirm that we have the same problem - the timer stopped working within first 6 months...........very frustrating having to re-do every time!
    Problem Solver:
  • 7 Answers
Replace the timer unit as you cant repair them
Posted on Jul 20, 2008
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Defrost timer starts running when freezer door is opened
The defrost timer motor is weak and the simple vibration of opening the door gets it working again...replace the defrost timer and you'll be good again.
Feb 04, 2012 | Refrigerators
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
MDB7600aws Maytag dishwasher heats up with door shut when off
Your timer is jamming on the heat cycle. When you open the door the door interlock switch cuts the power off and stops the cycle.
Probably if you just close the door again it will heat again unless the machine is started again.
You need to repair or replace the timer.
Mar 16, 2010 | Dishwashers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Not draining, stuck on first wash cycle.
The heating element is your most likely suspect. The timer will not advance until the proper water temp. is reached. After the cycle runs for 5-10 minutes, crack open the door. Let the water stop flying around. Open the door wide. You should have released a big ball of steam from inside the machine.
No steam = no heat = no timer movement.
The heating element and the wires leading to it need to be checked and tested. Specifically, check the resistance of the element. You should get a real reading from it on a multitester, not zero or overlimit or infinity. If you can handle all of this, any repair/replacement should be no problem. Good luck
Dec 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
Sep 20, 2009 | Frigidaire Dishwashers
Heating element turns on when you turn on timer door open
Sounds like the door switch is broken.Fairly easy to replace.
Feb 16, 2009 | Frigidaire GLER642A Electric Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
121 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
