Question about Sony DRU-820A DVD RW Dual Layer Burner
Sony DVD RW DRU-820A
WinXP Pro SP3 complete, with SONY DVD RW DRU820A drive. Recently I cleaned my system and put it all back. All seemed well, but when tried to put disk into SONY DVD RW DRU820A, the disk whether CD or a DVD just gets ejected instantaneously. Please HELP!
Well this got sorted off. But now the TRAY would'nt budge open!
Waaaah! Help!
    Genius:
  • 1,019 Answers
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Posted on Jul 01, 2008
I have a Sony DVD DRU-820A burner. When I insert a dvd--either a blank one to burn or a DVD disc to view--the name of the drive switches from DVD-RAM Drive (D:) to CD Drive (D:). The burner no longer burns...
The device is _partially_ broken -- the part that reads/writes DVD media is "dead".
Spend $40 to purchase a new CD/DVD reader/writer, to replace the "dead" unit.
Dec 20, 2010 | Sony DRU-820A DVD RW Dual Layer Burner
I have a sony dru 820a dvd writer,it is not detecting the cd/dvd when inserted but it makes some wierd sound and does not read the inserted media. it was also interferring with booting of PC but once the...
ur registry is corrupt...
try cleaning the registy
visit my website www.sureshayyar.110mb.com
go to dowload page in there...get Tuneup Utility...install, clean the registry....
also try runing chkdsk...if u know how to do it...
all the best
Dec 25, 2009 | Sony DRU-820A DVD RW Dual Layer Burner
Sony DRU-820A DVD RW Dual Layer Burner not working
Download the most current drivers for your Chipset. Uninstall the drive via Device Manager, restart your system and let Windows install it. Update to the latest Windows Service Pack. Download the updated Firmware version and internal drivers from here:
http://sony.storagesupport.com/product/125#documents
Hope this solves your problem
Regards,
Tim
Oct 07, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Sony dru-820a not working
Check the divece settings in the bios i.e. SATA, ATA, IDE
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Can make a data dvd but cannot read it on comp. but can read it on another comp
Resolved, unsure what I did but a full re-install of xp and all is working after I did my final windows updates. keep in mind that a fresh install of winxp sp2 with none of 88 recommended patches it still wasnt working
Jan 05, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
DVD - Slow burning speeds
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try http://www.pcpro.co.uk/reviews/87363/sony-dru820a.html also worth trying is updating the drivers http://drivers.softpedia.com/get/FIRMWARE/Sony/Sony-DRU-820A-10b.shtml to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Feb 28, 2007 | Sony DRU-820A DVD RW Dual Layer Burner
Sony DRU-820A DVD RW Dual Layer Burner Logo
249 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
