Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Difficult to Establish Connection
Wireless/Wired Network, laptops and desktops require ip config release/renew each session as well as web pages that load in new window fail to connect for extreme periods of time. seems to work reasonably well for pages that load in same browser window. DSL, Belkin Wireless G, multiple laptops and desktops various cards
  • fixme3 Jul 01, 2008
    please help
  • Anonymous Mar 18, 2014
    network anomaly, loading failed. Computer is working properly. wired and wireless setting are not working. Unable to watch anything.
  • 611 Answers
Do one thing at first you configure your dsl and after same configuration in the wireless g,
then configure the laptops to installed the card driver.and destops also where you want to installed
the card.
Posted on Jul 02, 2008
Dap 1160 Problem access web admin page
connect device directly to your computer using Ethernet cord. try to release and renew IP from the command prompt
IPCONFIG /RELEASE
IPCONFIG /RENEW
IPCONFIG /FLUSHDNS
then perform ipconfig. From there you will be able to get the IP address of the access point that you will need when accessing web admin page
Dec 22, 2012 | D-Link DAP-1160/B ACCESS POINT, WLESS G,...
Unable to obtain valid IP config
Unplug power to ISP modem, till you see it reboot. Test with a cable to establish you can connect directly with ISP modem. If OK, reconnect with wireless modem. You will have to switch between wireless and regular network adapter on laptop for this test.
Use these instructions to test and see IP's.Go to Start > Search > Type cmd and hit enter key.
In Command Shell:
Type ipconfig /all These are your IP settings.
Type ipconfig /release To clear IP settings.
Type ipconfig /renew For new IP settings.
You will need to check NIC drivers in Device Manager if problem persists.
Oct 02, 2012 | Gateway M Computers & Internet
Intermittently, my home network and internet access ceases to function. Troubleshooting indicates the "Local Area Connection" doesn't have a valid IP connection. Resetting the router (12...
Going inot the router configuration page and reserving your computer with a specific IP address would resolve this issue, If you have never gone into the router config page, it would be reccomended that you not do this, and have a computer savvy person with networking experiance do this for you.
another solution would be releasing and renewing your IP address in the command prompt on your computer
in command prompt, type : ipconfig /release ENTER then ipconfig /renew to renew your ip address, this can be done rather than resetting the router everytime
Jul 02, 2011 | D-Link DIR-615 Wireless Router
I have a Dell Dimension 4600 with a 2wire modem/router combo. The wireless internet connections work flawlessly with all wireless laptops, phones, games, etc. I cannot access the internet on the pc itself...
You may have a problem with your IP and DNS settings. Please use the instructions below
Go to Control Panel>Network Connections and select your local network.Click Properties, then select Internet Protocol (TCP/IP).Click Properties. You will see a window like the one below. Please make sure that the settings are all set to automatic for your IP4 and/or IP6 connections.
Source: http://www.mediacollege.com/computer/network/dns.html
If that doesn't work, please try to renew your ip settings.
This can be done with the following steps:
1. Open cmd.exe
Windows XP: Start - Run - cmd.exe
Vista/7: Window Button - type "cmd.exe" - Enter
2. Type "ipconfig/release"
3. Type "ipconfig/renew"
4. Wait for connection to establish.
Dec 21, 2010 | Computers & Internet
My acer aspire 5630 will no make the connection to the internet using the wireless. if i hook it up hard wired it works fine. I also tried a USB wireless but it would not make the connection that way...
Try to release and renew the IP address:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Dec 13, 2010 | Acer Aspire 5630 Notebook
Cannot renew ip address
You may have to perform a DNS Flush..Sometimes with wireless, the laptop cache in the IP address that is used when you are connected wirelessly. You can Flush this down the toilet by performing the following command at a DOS Prompt by going to run, and type in CMD, then input the following command in. Once this is done, try to renew your IP again!!
C:\>ipconfig /flushdns
May 12, 2009 | Computers & Internet
Internet Explorer cannot display the web page
your router needs to be configured to let your laptop in the network
Apr 09, 2008 | IBM ThinkPad R50e Notebook
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
80 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
