Adding coolant Had my 2002 Deville serviced last week and now the check coolant level has come on. I bought some coolant but can't get the cap off.
Thanks, but, all I needed to know was how to get the cap off the coolant tank...gave up!!!!
Posted on Jul 02, 2008
2000 cadillac deville is overheating, replaced thermostat: water pump radiator had head gaskets fixed it's saying check coolant level and it spews coolant from the overflow tank cap when hot thoughts?
Two cooling fans controlled by three relay's . If only one fan is working ,that could be a problem .
Coolant Level Sensor Description
The coolant level sensor monitors the coolant level in the cooling system and indicates if the coolant is low. This sensor is located at the base of the radiator surge tank and is not serviceable.
CHECK COOLANT LEVEL (2)
The IPC receives a discrete input from the engine coolant level switch. The engine coolant level switch is normally closed. When the engine coolant is low, the engine coolant level switch opens. When the IPC receives an open signal from the engine coolant level switch, the IPC displays the message on the DIC.
Relay Driven Dual Cooling Fan Diagnostics There are using a pontiac , by your cadillac is the same .
Mar 24, 2017 | 2000 Cadillac DeVille
99 Cadillac Seville coolant light coming on. No apparent leakage. Adding coolant 2 to 3 times a week with little driving. Sometimes an anti freeze haze appears on inside front windshield .
HAVE YOU CHECKED YOUR COOLANT HOSES? CHECK TO MAKE SURE THERE NOT LOOSE OR CRACKED. ANOTHER THING COULD BE IS YOUR HEATER CORE HOSES COULD BE BAD. ALSO I WOULD CHECK YOUR RADIATOR CAP THE SEAL COULD BE BAD. I HOPE THIS HELPS YOU WITH YOUR TROUBLESHOOTING.
Sep 22, 2013 | 1999 Cadillac DeVille
2001 cadillac deville check coolant level but level is good.
Your coolant level switch at coolant tank may be bad,click here to see.
Nov 29, 2012 | 2001 Cadillac DeVille
My 2001 cadillac deville has check coolant level
If you added the green anti freeze to you system it will make the check coolent level light come on. Drain the system and use the extended life anti freeze and that will fix the problem.
Jun 30, 2012 | 2001 Cadillac DeVille
How do i remove engine coolant cap on 2001 cadillac dhs
WAIT UNTIL YOUR ENGINE IS COLD,YOUR RADIATOR PRESSURE CAP IS LOCATED ON THE COOLANT OVER FLOW RESERVOIR, THATS WHERE YOU ADD COOLANT WHEN COOLANT LOW,YOU POUR COOLANT IN THE OVER FLOW RESERVOIR UNTIL COOLANT LEVEL REMAIN AT FULL COLD MARK DONT OVER FILL OVER FLOW RESERVOIR, WHEN COOLANT LEVEL STOP DROPPING WHEN ADDING COOLANT AND COOLANT LEVEL STAY AT COLD MARK ON THE RESERVOIR YOU RADIATOR HAS THE CORRECT COOLANT LEVEL IF COOLANT LEVEL KEEP DROPPING CHECK FOR COOLANT LEAKS AROUND RADIATOR AND THE TOP AND BOTTOM RADIATOR HOSES, LOOK FOR COOLANT LEAK AT WATER PUMP GASKET OR SEAL OR LEAK AT WATER PUMP WEEP HOLE IF YES REPLACE WATER PUMP.
Oct 23, 2011 | 2001 Cadillac DeVille
Looking for the fill plug on a 200 dodge darango 4 wheel drive front punkin all i see is a vent pipe
COOLANT-ADDING ADDITIONAL
Do not remove radiator cap to add coolant to system. When adding coolant to maintain correct level, do so at coolant reserve/overflow tank. Use a 50/50 mixture of ethylene glycol antifreeze containing Alugard 340-2 y and low mineral content water.
Remove radiator cap only for testing or when refilling system after service. Removing cap unnecessarily can cause loss of coolant and allow air to enter system, which produces corrosion.
COOLANT LEVEL CHECK
The cooling system is closed and designed to maintain coolant level to top of radiator.
WARNING: DO NOT OPEN RADIATOR DRAINCOCK WITH ENGINE RUNNING OR WHILE ENGINE IS HOT AND COOLING SYSTEM IS UNDER PRESSURE.
Remove radiator cap. The coolant level should be to top of radiator. If not, and if coolant level in coolant recovery bottle is at ADD mark, check for:
  • An air leak in coolant reserve/overflow tank or its hose
  • An air leak in radiator filler neck
  • Leak in pressure cap seal to radiator filler neck
TRANSMISSION and OIL LEVEL CHECK TUBES
Mar 04, 2011 | 2000 Dodge Durango
I have a 2002 cadillac dhs and the check coolant level comes on. why is this happening. I had the system flushed and it still comes on. Also, my check system stablilizer comes on also. Please, I do...
Re: I have a 2002 cadillac dhs and the check coolant level comes on. The coolant sensor is located in the overflow bottle and it is prone to failure. Unfortunately the only way to get it is to repl. coolant overflow bottle.
Nov 28, 2010 | 2002 Cadillac Deville
2002 Honda VTX 1800 radiator cap location
Hi, Sshadeebill for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Coolant level and radiator cap
2004 honda Vtx 1800C coolant adding part 2
Honda VTX1800R Owner Manual service manual, not owners.
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2005 VTX1800C Owner Manual
Jul 22, 2010 | 2004 Honda VTX 1800
My 2002 Cadillac Service Engine Light came on, code scanned for Catalytic converter. I replaced the converter after 2 weeks light came back on as well as alerts foe check gas cap, and check coolant level....
the code for gas cap? is also a code for small leak in evap system which includes the fuel /vent lines and canister check that the lines weren't damaged when cat was put in also check coolant sensor in reservoir connections runs by exhaust system
Nov 01, 2009 | 2002 Cadillac Deville
Car overheating, Cadillac Deville
maybe it is cloged up. also check the fans. and the thermastat. and temp sensor.
Nov 21, 2008 | 2002 Cadillac Deville
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
