Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic PT-47WX53G Projection TV - convergence problem, can not align completely
I have a Panasonic PT-47WX53G 47" Projection TV that developed a convergence problem a few months ago. I ordered from Panasonic the factory service manual. From that and talking a panasonic factory shop they thought it could be the convergence board. I ordered and replaced the convergence board DC-board p/n TNPAA120. It took 3-4 months to receive the board, pluged it in and still had the same problem that it will not align all the way. All the alignment is done in software via the remote. I also bought the factory alignment template to help with the alignment but it just won't align all the way. Any help here would be appreciated.
  • 4 more comments
  • hispeedguy Jul 28, 2008
    Same exact problem on exact model
  • helmershawk Nov 28, 2008
    I have the same problem with just the red. I going to do some more research I'll let you know what I find.
  • mos63 Jan 08, 2009
    I have the same problem with the red....did helmershawk find any answers?
  • skdiddle Jan 11, 2009
    I have the same problem but the side to side line in converge will not line up thru the remote it will not move all the way over and it is not straight. Any ideas
  • Flex Feb 03, 2009
    HiDefDad,
    Bingo, thanks for taking the time to answer my plea. That was top notch. I had given up on the TV but did not through it away. I pulled the board out very careful. I checked the 6 resistors and they were good visibly and by ohming them out. I then ordered the 2 chips on eBay from the same company that you mentioned for about $16 including shipping from Electronix, had the chips 3 days later. Installed them and then I was able to bring the convergence back. A pain in the but because I spent some much time before trying to align them. It is mostly good, some curve lines at the top don't want to straighten out, small red lines at top and bottom are just slightly off but only shows if you look hard. Since you are so good at this, any fast ways to re-align the colors especially red. Never the less, thanks alot. Another note, when soldering, make sure you use the lead-free solder like recommended by the manufacturer. Felix
  • Flex Feb 04, 2009
    Thanks again for your input, that's what I used to do the alignment by going into the service menu, I used all the options, the convergence is aligned in all but the top small area and similar at the bottom, even when it curved a little, I got most of the convergence to be the same. It is just that last little bit. Had I know what you know about the chips and not made any adjustments in the beginning, maybe it would be perfect now. I guess I just have to keep messing with it, to get that just right combo. Felix
I don't know why that guy told you to replace your "DC" board (that is the one you mean, right?) More likely than not, it's your convergence amp integrated circuits (ICs). I had what I think was the same problem (on the same exact model TV) you described, and I looked around alot of blogs and DIY websites, and this seems to be the most prevalent root behind these convergence problems. I ordered the two chips for twelve bucks (for both), spent a few extra bucks (like $35) on some electronic tools / solder supplies, and followed procedures laid out here at http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html, as well as paying strict attention to the service repair manual (which you said you already have?). The result? No more convergence problem, and I saved myself around $400 - $550 over having it done by a professional.
Seriously-- I bet this is the culprit. Just make sure if you're gonna do this that you FIRST check the six resistors (located at spots D-7011 thru D-7016) to make sure there are none burnt out / opened. It may be that one of those is fried also / instead. Since they are far easier to replace, it's good just to rule them out first.
And by the way, just FIY, when I did this I had kept the TV unplugged for about two weeks first, cuz I wanted to make sure all the capacitors were discharged and safe. Did I need that much time? Maybe not (some have said a few hours is sufficient), but I was also primarily concerned about the Flyback Transformer and its wires, which have the highest voltage (up to 30,000 volts) and can hold a charge pretty long. And I'm still here to write about it. So, check out the link, and see if you'd like to try this yourself, as well!
Posted on Jan 16, 2009
  • HiDefDad Feb 04, 2009
    I had the same thing happen after my chips were in. It is just an unavoidable result of having changed the chips. The regular nine-point convergence feature in the consumer's remote control menu just wasn't fine tuned enough to get everything to come into proper alignment. What you want to do is use your repair / service manual. It shows you how to get into the serviceman's repair menu with your remote so you can do the extremely fine tuned convergence (at like a couple hundred points, and for all three colors blue green and red, not just blue and red). This is where having your template will really pay off (I never got one -- didn't want to part with the money). The only thing is, this serviceman's adjustment menu can tweak things most consumers should never be allowed to mess with, because if you goof something up, you can really have a terrible time trying to figure out how to undo what you did wrong. However, this menu, when properly read in your manual and understood, can help you not only to get your convergence back to brand new quality, but also to optimize little nuances of the quality of your picture that can be thrown off over time with normal usage of your TV. Stuff like focus of the lenses, the trapezoidal pitch of the shape of the screen, etc. etc.
    So be hopeful. But be careful, too...
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53G Convergence Problem - board replaced still does not align
Unfortunately your best bet is to have a professional take care of it. You tried manual or auto convergence? Was there any change? If you need any help contacting a professional I will be glad to assist you.
Thanks,
Lee
Jul 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How do i remove the convergence board on my panasonic hdtv projection model number PT-47WX53G and is the any risk in electocution even after beeing unpluged
You have to remove all the cables and screws first...if you not sure how its done you can goto sites like www.TvRepairKits.com that have the parts and instructions to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem on pt-47wx53g
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I cannot get the blue convergence cross to line up with others.
The tv convergence board is dead.Any colors G,B,R don't alignment matches up.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic pt-47wx53g picture looks like it is 3D. What do I need to do.
Install the PT53WX53 convergence repair kit available from www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with repair instructions.
Jan 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double vision
Its a repair you can do yourself for under 40.00 if you can solder . You need to replace both convergence ICs they are both STK392-110. You can get replacement ICs at the following link with free instalation instructions with pictures. TV shops generally charge between 400 and 600.00 for this repair which takes about an hour.
Heres the link
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
4,179 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
