Question about Canon PowerShot SD870 IS Digital Camera
Cannon Powershot SD 870
I have the Canon Powershot SD 870 and I am having a problem when in the flash in Auto mode, the pictures turn out with a dark background when in Auto mode and the flash does flash. What is wrong? I am not happy with this camera, I also have alot of red eye problems even with the red eye reduction on.
You can change it to no flash by when your taking a picture press the right arrow
Posted on Jul 19, 2008
Hi, I have a Cannon Powershot A610 and when I take a picture the picture comes out too dark. How can I adjust the it? thanks
"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 06, 2011 | Canon PowerShot A610 Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
Pictures are very dark.
Are you shooting on "Auto" or any other mode?
Apr 09, 2009 | Cameras
Falsh Problem with Power Shot a640
I had the exact same problem. You'll need to send it back to Canon. It'll cost you $87-94, but they'll clean it up, get the flash working, and make it new again. It's a good camera worth getting fixed.
Sep 14, 2008 | Canon PowerShot A640 Digital Camera
In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Dec 09, 2007 | Canon PowerShot A70 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Cannon powershot sd 300
flash may have been dislodged and out of true. or may be the lens is out of alignment or a shutter blade is not functioning. Dropping them sure does them no good at all. Into the repair shop with it
Jun 03, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
CANON POWERSHOT A-85 FLASH PROBLEM
Watch the flash,(this might hurt your eyes a bit. If you are getting dark pictures the flash may not actually be firing without you noticing it. It is also possible that the output of the flash is not as high as it should be. This is not very likely though. Either way, since you have tried all posible settings, you are going to have to take it to a shop.
Mar 28, 2007 | Canon PowerShot A85 Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
163 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
