Question about InFocus LP210 Multimedia Projector
Infocus led diagnostic
I have an INFOCUS LP 240 the led is flashing red and it keeps powering itself down PLEASE HELP ME
  • 1 more comment
  • raveon1 Jul 01, 2008
    hi i have got an INFOCUS LP240 and its suddenly stopped working while i
    was watching a film it will turn on and light up as normal but afta 30
    secs or so it turns of and the L.E.D next to power button flashes red
    and green wat do i do PLEASE HELP ME!!!!!!!!!!!!!
  • sagertronics May 11, 2010
    How many flashes between pauses?
    the LED will flash a specific number of times with a pause between each group of flashes. How many times does the LED flash between pauses?
  • 2,237 Answers
It might be overheating. clean off the dust filters (bottom towards the front). if there's not enough airflow to cool it down, the projector will shut off to save itself from damage.
Posted on Jun 05, 2009
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
I actually have a 250. bulb is new but stopped working. When plugged in green power indicater lights then flashes two red lights.
The projector is bloked, you need reset the lamp timer. Press and hold the VOLUME + buttom, then press the VOLUME - buttom. Hold both buttons down for 10 seconds.
Jun 16, 2010 | InFocus LP 240 Multimedia Projector
Infocus 250 will not turn on at all.
The power button is solid green? try to turn on whit the remote control. Try to clean the surface on the Main board, uder the contro panel.
May 31, 2010 | InFocus LP 240 Multimedia Projector
Hi, I have an LP Infocus Projector. The fan kicks on but light does not come on. Green light on top keeps flashing, what could be the problem?
it can't strike the lamp. either the lamp is dead or the ballast has dried-up caps. a colorwheel malfunction will also cause the lamp to not strike, but you would get a red led, not a green. if the lamp center has bulges, cloudyness, and/or black spots, replace the lamp. otherwise, you'll want to replace the ballast. you can send it in for repair (or buy the part and do it yourself) from an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus 4805 shuts down after running for ten min help
try holding the input and menu button on the set itself both together for 8 seconds this should flash a diagnostic code on the set and cause the led to blink a 2 digit code and let me know what that code is and I will try to help you
Apr 08, 2008 | Televison & Video
InFocus LP210 Multimedia Projector Logo
370 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
