How do you know the BCM is at fault ? Did you hook up a factory or someother type professional scan tool an check for DTC'S - diagnostic trouble codes ? Did you view how these system work in factory sevice repair information ? Did you use a wiring diagram an DVOM - digital volt ohmmeter an test electrical circuits ?
The BCM has nothing to do with the memory seats .
Memory Seat System Components
The memory seat system consists of the following components:
• Power Seat Switch
• Seat Horizontal Motor
• Seat Front Vertical Motor
• Seat Rear Vertical Motor
• Seat Recliner Motor
• Driver Seat Module
• Memory Seat Switch
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Rear Wiper/Washer System Components
The rear wiper/washer system consists of the following components:
• Rear window wiper motor
• Rear washer pump
• Rear wash relay
• Rear wiper/washer switch
• RR WIPER Circuit Breaker 15A / ENDGLASS REG Circuit Breaker 30A
• WASH 20A fuse
• Body control module (BCM)
• Liftgate control module (LGM) / End gate module (EGM)
Rear Wiper Operation (with LGM)
The rear window wiper/washer switch is an input to the BCM. The requested rear wiper mode is sent to the LGM by the BCM, as a message on the serial data circuit. The rear window wiper motor is controlled by the LGM. The switch power circuit to the rear wiper/washer switch is a 12-volt reference supplied by the BCM during ignition on, accessory or RAP power modes. The rear wiper/washer switch is composed from a series of resistors and the switch position is determined by the voltage of the rear wiper/washer switch signal circuit to the BCM. The rear wiper/washer switch has continuity at all times and the BCM expects a rear wiper/washer switch signal voltage in all switch positions including OFF. The rear wiper motor is supplied battery positive voltage and ground. The LGM controls rear wiper motor operation through the rear window motor speed signal circuit. The rear window motor speed signal circuit is supplied a battery positive reference voltage by the rear window wiper motor module and is pulse width modulated to ground by the LGM. The duty cycle of the pulse width modulation determines the rear wiper motor operating mode. The liftglass and liftgate ajar switches are inputs to the LGM and must be in an inactive state in order for rear wiper washer system operation to be enabled. When an ajar switch is active the LGM suspends wiper motor operation directly and sends the ajar switch status messages over the serial data circuit enabling the BCM to suspend washer pump operation.
Rear Wiper Operation (with EGM)
The rear window wiper/washer switch is an input to the BCM. The requested rear wiper mode is sent to the EGM by the BCM, as a message on the serial data circuit. The rear window wiper motor is controlled by the EGM. The switch power circuit to the rear wiper/washer switch is a 12-volt reference supplied by the BCM. The rear wiper/washer switch is composed from a series of resistors and the switch position is determined by the voltage of the rear wiper/washer switch signal circuit to the BCM. The rear wiper/washer switch has continuity at all times and the BCM expects a rear wiper/washer switch signal voltage in all switch positions including OFF. The rear wiper motor is supplied battery positive voltage and ground. The EGM controls rear wiper motor operation through the rear window motor speed signal circuit. The rear window motor speed signal circuit is supplied a battery positive reference voltage by the rear window wiper motor module and is pulse width modulated to ground by the EGM. The duty cycle of the pulse width modulation determines the rear wiper motor operating mode. The rear window motor park signal circuit provides position status of the rear wiper to the EGM.
The rear wiper and washer operation is allowed if the following conditions are true:
• Power mode is run or accessory.
• Lower left ajar switch is closed.
• Upper left ajar switch is closed.
• Upper right ajar switch is closed.
• Upper left dome switch is closed.
• The end gate window is fully closed.
• No end gate window express down, up, or down is requested.
• No gate swing open or drop open is requested.
If rear wiper/washer operation is attempted and the end gate window is open the driver information center (DIC) displays "Tailgate Glass Down". If the rear wiper is not in the park position and an attempt to open end gate window is done, the DIC displays "Rear Wiper Obstruction".
Your best bet , take it to a qualified repair shop because you have no idea how these systems work .
I think it's a magneto ignition which means it should spark unless the (white ?) wire between the coil and the ignition module is earthed. To stop the motor this wire is connected to earth by either the key switch (turning key to "Off") or the ignition relay drops out (can happen if the seat switch is not switched on). Probably worth checking the seat switch is working reliably early on.
Simplest way to check is to find the stop wire and disconnect it (leaving the coil connected to the ignition module). You'll have to re-connect to stop the motor, or short the coil - ignition module wire to earth.
See bottom circuit diagram.
Good luck.
Not a fuse issue , more then likely a burnt heating element in the seat , happens all the time .
Heated Seat Components
The heated seat system consists of the following components:
• Driver and passenger heated seat switches
• Driver and passenger seat back heater elements
• Driver and passenger seat cushion heater elements
• Driver and passenger seat back temperature sensors
• Driver seat module
• Driver door module
• Passenger door module
The control module have a Battery voltage supply , the module supply's voltage to the seat heating elements .
The heated seat switches are momentary contact switches and are inputs to the driver and passenger door modules. Battery voltage is supplied to the switch assembly from the door module, and when a heated seat switch is pressed and released a brief switch signal voltage is supplied to the door module. Whenever the door module receives an active heated seat switch input, the next heated seat operating mode is determined by whatever the current mode may be. The seat heater elements are controlled by the driver seat module using inputs from the door modules through Class 2 serial data circuit messages. The driver seat module controls the voltage supply and the ground circuits to the seat heater elements. When a heated seat function is commanded active, the seat module will switch battery voltage to the heater element supply circuits, and ground is provided through low side drive control circuits. During heated seat operation both the seat back and cushion heater elements are supplied battery voltage. The seat module grounds the appropriate control circuits for back only or back and cushion heating modes, and opens or closes the active control circuits as necessary in order to maintain the desired seat temperature. The seat module relies on inputs from thermistors located in the driver and passenger seat backs to control heated seat temperatures. The thermistors are 2 wire sensors supplied with a 5-volt referenced signal circuit and a low reference circuit from the seat module. Resistance through the thermistors varies with temperature causing the heated seat sensor signal circuit voltage levels to decrease as the seat back temperatures rise. The seat modules allow heated seat operation only while the engine is running which is determined by a Class 2 serial data circuit message from the powertrain control module.
Your best bet , take it to a qualified repair shop.
First try re-seating your ram modules to make sure they are properly seated. If that doesn't help try removing each module one at a time and restarting each time to see if start up is normal. Keep in mind to keep each module in it's original slot!! You can also try this free test: http://www.memtest86.com/ memtest86 hope this helps
The pad itself could be damaged. It contains quite a few strands running from side to side & after repeated seating & such will break. If you get to the plug in that comes from the pad & test for voltage there & have 12 Volts getting to it, but no heat, then more than likely that's the problem. There are many replacement types available including the newer "Carbon fiber" heated seats that just slip into where the old one was & then you just plug them into the orginal wiring with minor mods.
good luck.
Before you start beating up thing's , test the electrical circuits. Do you know anything about automotive electrical systems ? How to use a volt meter an a wiring diagram to test for B+ power to the switch an testing the ground .
Does your envoy have memory seats ? Your vehicle has four or more electric motors to control back an foward , up an down etc.. the odds of more then one motor being bad at one time are highly unlikely .
Look under the seat any trash under there keeping it from moving ?
If you have memory seats there is a control module involved in making the seats work . If it has memory seats it could have DTC'S - diagnostic trouble codes .
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820
The seat adjuster switches are inputs to the driver and passenger seat modules. The seat modules supply the adjuster switch assemblies with a battery positive switch supply circuit and monitor the switch signal circuits. In an inactive state the switch signal circuits are floating and when a switch is pressed the signal circuit is closed to the switch power circuit within the adjuster switch assembly. When battery voltage is present on the switch signal circuit the seat module determines the switch status to be active. DIY Blazer GMC Jimmy Power Seat Control Diagnostics and Repair Electric...
You have probably disloged the wireless module from the internals of the Treo. **KEEP IN MIND IF YOU DO THIS, YOU WILL VOID THE WARRANTY, if there is one** If you are out of warranty anyway, you can try to re-seat the wireless module by removing the screws with a T5 Torx head screwdriver, then removing the back plate and re-seating the module.
