Question about Motorola Mobility H700 Wireless Headset
Power won't come on
I have a new fully charged H700. The light is steady green when the charger is plugged in. When I unplug the charger and open the boom I get nothing. No light of any color, no steady, no blinking. Nada. I assume there is an internal switch that isn't connecting. Pressing or pressing and holding the call button has no effect. Any way for me to fix this?
  • Anonymous Nov 02, 2008
    I have a Motorola H700 Wireless Headset and the power won't come on. I have charged the headset for 8 hours. What can I do more? I have never used it before (new).
  • djups06 Apr 22, 2009
    Upped. Mine neither. And I bought it new off craigslist. (They said it hadn't been opened). I'd hate to be out my money. But yeah, mine is fully charged (I get the green light). Other than that it doesn't respond. Opening the boom does nothing, nor does holding the call button.
I am having similar issues. Before you OPEN the boom, press and hold the CALL button in the middle and ensure your Bluetooth is paired/synced with your cell phone.
Press and HOLD about 5 seconds until the PURPLE light illuminates. Then flip it open immediately and begin the pairing process.
My problem is that the purple light won't illuminate at all...
good luck
Posted on Jul 02, 2008
I have the same issue, i tried what you said above but it did not work at all, any other solutions at all, or should I just dump it ???
Posted on Oct 30, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
It wont turn on
With the boom closed, insert a plugged in charger and make sure the unit is fully charged. The light will turn from amber to GREEN when it is fully charged. Unplug the charger and open the boom. It is now "on".
Aug 23, 2009 | Motorola Mobility H700 Wireless Headset
H700 wont do anything
I think the charger is the problem. I ordered one of these and then it wasn't charging the day I got it....it's supposed to go from red, to orange to green as it charges, but the red LED just goes off after a while, before the headset is fully charged. I solved this by charging it through a USB-to-miniUSB cable on my laptop USB port. This worked beautifully....unfortunately I think the H700 chargers are faulty.
Feb 09, 2009 | Motorola Mobility H700 Wireless Headset
My Motorola H700 Will Not Pair
I had the same problem and I keep trying and trying 1234, 0000 and other numbers I can think of. It was frustrating. I was ready to throw my device away and buy a new one. Then I tried something that I have not and it worked. All I needed to do is to press the big button in the center of the H700 until it turns purple steadily. And then I pulled out the microphone of the H700. The button remained purple. Then I typed the password 0000 into my cellphone. The button will flicker indicating it's finally communicating and then it finally did!. Try that. Hopefully it works for you too. It worked with mine.
Jun 09, 2008 | Radio Communications
H700 will not turn on. NO LIGHTS
I have the same issue. Bought 10 new H700's and 3 of them will not turn on. Still trying to find a fix.
Nov 20, 2007 | Motorola Mobility H700 Wireless Headset
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
515 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
