Question about InFocus LP70+ Multimedia Projector
INFocus LP70+ I cannot get a welcome menu or user menu on my INfocus LP70+. I plug it in, turn it on, the fan comes on, the lamp lights, all light indicates are normal. The green light blinks until I connect it to a inout source then remains on green. HELP !
    Problem Solver:
  • 11 Answers
Soundz like input board or mainboard. try avalontc.com
Posted on Aug 06, 2008
Light does not come on, fan is working and green light at top keeps blinking off and on on a LP70 infocus projector
if you hear a high-pitched whir, the problem is either the ballast or the lamp. if you don't, it's the colorwheel. you could try to get the parts from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 22, 2009 | InFocus LP70+ Multimedia Projector
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
LP70 lamp will cycle on and off in 3 min. intervals.
go into the menu and check the lamp hours. if it's over 2000, you need to replace the lamp. if it isn't, the power supply and/or ballast is starting to fail.
Jul 06, 2009 | InFocus LP70+ Multimedia Projector
I want to test my infocus lamp to know if it is burnt
Your lamp might be ok, but you power supply is dead. If your not seeing any led lights come on when the power cord is plugged in then your power supply is dead. I can fix this for you for less then it cost to send to infocus or to a repair shop. Ebay Id is Gtitubro
AIM - Gtitubro
Feb 12, 2009 | InFocus Lamp Projector Lamp for LP650,...
Infocus projector lp70
in order for the lamp to strike and stay on, the fans and the colorwheel must be spinning and up to speed. if you remove the lamp and start it up, see if the 2 fans are spinning. and look inside to see if the colorwheel (a colored glass disk) is spinning. you'll also be able to hear a high-pitched squeal coming from it. unfortunately, you'll need to take it in to a repair center to have them replaced.
Jun 21, 2008 | InFocus LP70+ Multimedia Projector
Infocus LP350 won't show signal, also panel buttons don't light up
Hi LuckyLindy
Next time this happens , just take out the main connection to the Mainboard and plug it back in.
Also remember to reset your lamp timer now that you have replaced the lamp !
Apr 24, 2008 | InFocus LP350 Multimedia Projector
Pile of ##@!#@ infocus lp70 green light wont come on. should i smash it??
if the fans aren't running, it's the power supply. if the amber is on and the button's won't turn it on, there is an obstruction under the button panel. if all turns on but the lamp and you don't hear a high=pitched whir, it's the colorwheel. if you do, it's the ballast.
Dec 20, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
145 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
